073-010_ALT_0
Common Anode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors
Brand:| Model: DC-LE11116
This package includes 100 common anode RGB LEDs together with 600 voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
  • Rated to last over 10 years
  • Includes 600 voltage dropping resistors (300 for 5 VDC, 300 for 12 VDC)
  • Up to 5,000 mcd of output
073-010
Weight: 0.25 lbs.
IN STOCK
$28.85
Buy 4-up$25.97
Part # 073-010
RGB LEDs Light Emitting Diode are great for creating custom light effects for displays, in vehicles, on motorcycles, instrument panels... anywhere accent lighting is needed. This RGB LED is waterproof for use on boats or outdoors and are tested to last 100,000 hours (over 10 years) and use virtually no power at all—1/4 watt at most—while providing up to 5,000 mcd of output. Also included are resistors to use these common anode RGB LEDs with 5 or 12 VDC sources.
When powered by 12 VDC, the red cathode should be wired with a 510 ohm resistor in series, while the green and blue cathodes should be wired with a 470 ohm resistor in series.
When powered by 5 VDC, the red cathode should be wired with a 180 ohm resistor in series, while the green and blue cathodes should be wired with a 100 ohm resistor in series.
Specifications: • Size: 5 mm • Lens color: water clear • Forward current: 20 mA • Life rating: 100,000 hours • Forward voltage: Red: 2 to 2.4 VDC, Green: 3.4 to 3.8 VDC, Blue: 3.4 to 3.8 VDC • Viewing angle: 25° to 35° • Luminous intensity: 4,000 to 5,000 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorRGB
  • Lens Type / ColorWater Clear
  • Luminous Intensity4000-5000 mcd
  • Application TypeTri-color
  • BrandParts Express
  • ModelDC-LE11116
  • Part Number073-010
  • UPC844632093395
  • Product CategoryLEDs
    (1 Reviews)
  • Weight0.25 lbs.
View similar products to the Common Anode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
Common Anode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors is rated 1.0 out of 5 by 1.
Rated 1 out of 5 by from It is not the same that is old thing.I bought the same part number in September 21, 2012.And I did the same thing in April 10, 2013.The pin description is not the same.Red output is the same but Green and Blue output is exchanged.So I was put in an awkward situation.Why did it changed?
Date published: 2013-04-26
  • 2015-02-25T08:24CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_073-010, PRD, sort_mostRecent
What are the dimensions of an individual light?
Asked by: 4325435435
These are 5mm LEDs.
Date published: 2012-12-17
Is Anode Pin 3 OR 4 ?
Asked by: Curious George
The longest lead is the common anode.
Answered by: RussR
Date published: 2012-01-07
100 LEDs, 600 resistors. 3 resistors per LED for 12v, or 3 for 5 volt.
Your description says to put a single resistor on common anode of LED. I would think the intention is to put aresistor on each cathode so you can light multi colors? Am I wrong?
Asked by: Speedracer
You are correct Speedracer. The copy has been updated to reflect correct usage of the resistors with the LEDs.
Answered by: mikevv
Date published: 2011-10-31
  • 2015-02-25T09:09CST
  • loc_en_US, sid_073-010, PRD, sort_recentQuestionsFirst
Customer projects that include: Common Anode RGB 5mm LED 100 Piece Kit with Voltage Dropping Resistors
