Common Anode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
Brand:|Model: DC-LE13136|Part # 073-110
This package includes 10 common anode RGB LEDs together with voltage dropping resistors for use with either 5 VDC or 12 VDC source voltages.
Part # 073-110
  • Rated to last over 10 years
  • Includes voltage dropping resistors for use with 5 VDC and 12 VDC
  • Up to 5,000 mcd of output
RGB LEDs are great for creating custom light effects for displays, in vehicles, on motorcycles, instrument panels... anywhere accent lighting is needed. These LEDs are waterproof for use on boats or outdoors and are tested to last 100,000 hours (over 10 years) and use virtually no power at all—1/4 watt at most—while providing up to 5,000 mcd of output. Also included are resistors to use these common anode RGB LEDs with 5 or 12 VDC sources.
When powered by 12 VDC, the red cathode should be wired with a 510 ohm resistor in series, while the green and blue cathodes should be wired with a 470 ohm resistor in series.
When powered by 5 VDC, the red cathode should be wired with a 180 ohm resistor in series, while the green and blue cathodes should be wired with a 100 ohm resistor in series.
Specifications: • Size: 5 mm • Lens color: water clear • Forward current: 20 mA • Life rating: 100,000 hours • Forward voltage: Red: 2 to 2.4 VDC, Green: 3.4 to 3.8 VDC, Blue: 3.4 to 3.8 VDC • Viewing angle: 25° to 35° • Luminous intensity: 4,000 to 5,000 mcd.
  • Size5mm (T-1 3/4)
  • Emitting ColorRGB
  • Lens Type / ColorWater Clear
  • Luminous Intensity4000-5000 mcd
  • Application TypeTri-color
  • BrandParts Express
  • ModelDC-LE13136
  • Part Number073-110
  • UPC848864000299
  • Product CategoryLEDs
  • Weight0.01 lbs.
View similar products to the Common Anode RGB 5mm LED 10 Piece Kit with Voltage Dropping Resistors
in the LEDs product category.
