Cobra CPI 200 CH 200W Power Inverter Cup Holder Design
Brand:|Model: CPI 200|Part # 125-335
Simply plug the attached cord into your vehicle's cigarette lighter or 12 Volt accessory port to convert 12 VDC battery power to 120 VAC household power. Its compact size and cup holder design make it ideal for travelers.
  • AC power that goes where you go!
  • 200 watts continuous power, 400 watts peak power
  • Ideal for video games, mobile phones and laptops
  • Cup holder design
  • Single AC outlet and 5 Volt USB output
  • Compact size
  • Low battery shutdown
Provides household power on the go! Simply plug the attached cord into your vehicle's cigarette lighter or 12 Volt accessory port to convert 12 VDC battery power to 120 VAC household power, allowing you to power up office equipment and household appliances from your car, truck, RV, or boat. It also has a USB output, ideal for charging and operation of most small video games and modern office devices such as iPods®, Blackberrys®, and mobile phones. Its compact size and cup holder design make it ideal for travelers.
Specifications: • Output power: 200 watts continuous, 400 watts surge • AC outlets: 1 • Output waveform: Modified sine wave • Output voltage: 115 VAC RMS ±5% • Output frequency: 60 Hz ±2 Hz • Dimensions: 7.41" H x 4.06" W x 4.03" D.
Note: To determine required wattage for a device (if the actual wattage rating is not given), look up the Amps a device is rated. The amperage is found on the device's ID tag, usually on the rear of the unit. Multiply the Amps of the device by 120 to determine required wattage (Amps x Volts = Watts). Choose an inverter with an equal or greater wattage rating.
  • BrandCobra Electronics
  • ModelCPI 200
  • Part Number125-335
  • UPC028377312656
  • Product CategoryPower Inverters DC-to-AC
    (1 Reviews)
  • Weight1.87 lbs.
View similar products to the Cobra CPI 200 CH 200W Power Inverter Cup Holder Design
in the Power Inverters DC-to-AC product category.
