Cobra CPI 130 Microport 130W Power Inverter Plug-In Design
Brand:|Model: CPI 130|Part # 125-330
Power up office equipment and appliances rated less than 130 watts, including most laptops. It also has a USB output, ideal for charging and operation of most small video games and modern office devices such as iPods®, Blackberrys®, and mobile phones.
List Price$44.95
You Save36%
$28.84
Buy 4+$26.21
Part # 125-330
  • AC power that goes where you go!
  • 130 watts continuous power, 260 watts peak power
  • Ideal for video games, mobile phones and laptops
  • Cigarette lighter plug design
  • Single AC outlet and 5 Volt USB output
  • Compact size
  • Low battery shutdown
The swiveling 12 VDC plug converts your vehicle's cigarette lighter or 12 Volt accessory port into 120 Volt AC household power. Power up office equipment and appliances rated less than 130 watts, including most laptops. It also has a USB output, ideal for charging and operation of most small video games and modern office devices such as iPods®, Blackberrys®, and mobile phones. Its compact size makes it ideal for travelers.
Specifications: • Output power: 130 watts continuous, 260 watts surge • AC outlets: 1 • Output waveform: Modified sine wave • Output voltage: 115 VAC RMS ±5% • Output frequency: 60 Hz ±2 Hz • Dimensions: 5.72" L x 2.53" W x 1.15" H.
Note: To determine required wattage for a device (if the actual wattage rating is not given), look up the Amps a device is rated. The amperage is found on the device's ID tag, usually on the rear of the unit. Multiply the Amps of the device by 120 to determine required wattage (Amps x Volts = Watts). Choose an inverter with an equal or greater wattage rating.
  • BrandCobra Electronics
  • ModelCPI 130
  • Part Number125-330
  • UPC028377312649
  • Product CategoryPower Inverters DC-to-AC
    (4 Reviews)
  • Weight1 lbs.
View similar products to the Cobra CPI 130 Microport 130W Power Inverter Plug-In Design
in the Power Inverters DC-to-AC product category.
