180-210_ALT_0
180-210_ALT_1
180-210_ALT_2
180-210_ALT_4
Coax Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack
Coax-Seal is a special material which will quickly and effectively seal all types of coaxial fittings of any shape from moisture, water and corrosion. Coax-Seal stays flexible for years thus insuring moisture proof connections. Four 12 ft. rolls per pack.
  • Seals electrical fittings from moisture and corrosion
  • Stays flexible at any temperature
  • Insures low SWR
  • Fast and easy seal for all antenna connections
  • Forms over odd shapes and sizes
180-210
Weight: 3.75 lbs.
IN STOCK
$26.25
Buy 4-up$24.88
Part # 180-210
Coax-Seal is a special material which will quickly and effectively seal all types of coaxial fittings of any shape from moisture, water and corrosion. Coax-Seal stays flexible for years thus insuring moisture proof connections. Insures good SWR and long coax life. Coax-Seal also allows you to disconnect and reconnect fittings with the same material by simply re-forming the plastic. Coax-Seal is the only material that will adhere to vinyl and poly vinyl connector outer covers. Coax-Seal is non-toxic, non-corrosive, non-conducting, and has hundreds of uses in electronics. 1" x 12 ft.\ Stays flexible at any temperature. Four 12 ft. rolls per pack.
  • BrandParts Express
  • Part Number180-210
  • UPC857142000005
  • Product CategoryMounting & Installation
    (1 Reviews)
  • Weight3.75 lbs.
View similar products to the Coax Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack
in the Mounting & Installation product category.
Coax Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from 1" Coax SealGood stuff! One inch width is much easier to work with than 1/2" width product. Not inexpensive....
Date published: 2012-09-10
Customer projects that include: Coax Seal Moisture Proof Sealing Tape 1" x 12 ft. Pro Pack
