320-336_ALT_0
320-336_ALT_1
Class AB 10W Mono Power Amplifier Kit TDA2030
Brand:| Model: AA-AK11231
This small, easy-to-assemble mono audio amplifier kit's Class-AB design provides up to 10 watts of pristine, accurate audio reproduction combined with an authoritative bass punch. Designed for use with 4.5 to 25 VDC power supplies (available separately).
  • Small, mono amplifier kit
  • Great kit for beginners
  • Supplies up to 10W of clean, clear power
  • Designed to work with 4.5 to 25 VDC power supplies (sold separately)
320-336
Weight: 0.15 lbs.
IN STOCK
$10.98
Buy 4-up$9.95
Part # 320-336
This Class-AB mono audio amplifier kit incorporates the TDA2030 power amplifier IC to deliver pristine, accurate audio reproduction combined with an authoritative bass punch, all in a small, hand-held sized package.
Assembly is accomplished in minutes, due to the easy to mount and solder through-hole components. Able to be powered by a wide voltage range of 4.5 to 25 VDC, this amplifier can suit a wide range of applications: active speakers, mini subwoofers, even mobile audio applications. Power supply not included.
Includes:
• PCB (L x W): 2-7/16" x 1-7/8"
• One TDA2030 amplifier IC
• Resistors:
One 680Ω (blue, gray, red, gold stripes)
One 4.7Ω (yellow, red, orange stripes)
One 4.7 kΩ (yellow, purple, red, gold stripes)
Four 22 kΩ (red, red, orange, gold stripes)
• Capacitors:
Three  470 μF, 35V electrolytic (black, white stripe indicates negative lead)
Four 22 μ  35V electrolytic (black, white stripe indicates negative lead)
Four 1 μF monolithic (small yellow, non-polarized)
• One green LED
• One heatsink
• Three screws (two for mounting the heatsink to the PCB, one for mounting the IC to the heatsink)
• One screw nut (for securing the IC to the heatsink)
  • Project Kit TypeUnassembled Amplifiers
  • BrandParts Express
  • ModelAA-AK11231
  • Part Number320-336
  • UPC848864001852
  • Product CategoryElectronic Project Kits
    (4 Reviews)
  • Weight0.15 lbs.
View similar products to the Class AB 10W Mono Power Amplifier Kit TDA2030
in the Electronic Project Kits product category.
Class AB 10W Mono Power Amplifier Kit TDA2030 is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from Great little amp!I bought this amplifier for a low power ham radio transceiver that only provided output for earphones. Easy to build, it took less than 30 minutes to construct. A wide range of DC input voltages makes it perfect for using with a wall wart. I'm happy with this little amp.
Date published: 2014-01-23
Rated 4 out of 5 by from Good, but missing screw terminalsI used this in a little amplified speaker project. Some observations:* it doesn't come with screw terminals although there are spaces for them on the board. Luckily I had some to hand but it would have been good to have that information in the product description.* I used it with a single full-range 8ohm, 20W speaker. It drives that well with plenty of punch at 14V but it's pretty quiet at 5V. If I increase the volume of the device driving it at 5V then the signal starts clipping. A 4ohm speaker might have been better.
Date published: 2014-01-21
Rated 5 out of 5 by from Cool little gizmo...I'm a noob. That last reviewer must be a tech whizz and an electronics god. I put this thing together with GREAT effort, (everything was so so tiny#. Using a magnifying glass straining my eyes and sweating bullets in two hours I got this thing put together. Stupid me got the wires crossed from the power supply and the TDA2030 amplifier ICexploded, #LOL). luckily I had another which I quickly soldered on and the the amp worked! All in all I loved this experiance. Still learning, but my eyesight is showing signs of aging.
Rated 5 out of 5 by from Great "tinkering" ampI'm working on a little project that requires an amplifier to drive a very small tactile transducer rated at 8 ohms. I ordered one of these and had it assembled in 15 minutes. Most of that time went to figuring out the ratings on the resistors. Initially I used an external power supply to operate the amp but then tried a 9v battery...it worked just fine, for my purpose. Assembly instructions are minimal, and good soldering skills a must. The TDA 2030 is probably overkill for my purposes and I'm not looking at audio quality at all, but for the money it's a great little project. Incidentally, the schematic with the kit specifies a 10k ohm potentiometer for volume control. Be sure to order one. One more thing: the heat sink supplied with the amp is bigger than needed if using a 9v power source. I'll be using something smaller for future builds.
Recomended simple 2 way Active crossover design kit...
Can anyone suggest a simple 2 way Active crossover design kit that a noob can make, which would be compatible with two of these amps.
Asked by: Twisted with Science
We do not have any kits available, but these amplifiers would work well with something like the Rolls active crosssovers.http://www.parts-express.com/term/rolls-crossover?m=172
Date published: 2013-05-08
Customer projects that include: Class AB 10W Mono Power Amplifier Kit TDA2030
