Clark Synthesis TST209 Tactile Transducer Bass Shaker
Brand:|Model: TST209|Part # 300-861
The Clark Synthesis TST209 tactile transducer provides depth and realism to movie effects and music in the physical way only a bass shaker can deliver!
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$129.99
You Save23%
$99.98
Buy 6+$89.00
Part # 300-861
  • Up to 10 times the force of the Aura Pro Bass Shaker
  • Mounts horizontally or vertically
  • Only one needed per seat -- acts as a silent subwoofer
  • Increases perceived loudness -- brings gunshots and explosions to life
  • Available exclusively from Parts Express
Clark Synthesis has led the design and production of tactile transducers for over 15 years. You can find their products in use by the US military in simulators to add a new dimension in realism that only a tactile transducer can provide. The Clark Synthesis TST209 tactile transducer is designed explicitly for home theater use and represents one of the best values on the market today. This high-tech bass shaker produces 1.6 lbs.-ft. of force per watt, with a peak force output of 216 lbs.-ft. Available exclusively from Parts Express.
Specifications: • Power handling: 100 watts RMS/350 watts max • Tactile frequency response: 15-800 Hz • Audible frequency response: 35-17,000 Hz • Impedance: 4 ohms • Transduction force: 1.6 lbs.-ft./watt • Peak tactile force: 216 lbs.-ft. • Dimensions: 8.0" dia. x 1.73" H.
  • ApplicationLow Frequency Bass Shaker
  • Impedance4 ohms
  • Power Handling (RMS)100 Watts
  • BrandClark Synthesis
  • ModelTST209
  • Part Number300-861
  • UPC645509002096
  • Product CategoryTactile Transducers, Exciters & Bass Shakers
    (23 Reviews)
  • Weight5.35 lbs.
Clark Synthesis TST209 Tactile Transducer Bass Shaker is rated 4.5217 out of 5 by 23.
Rated 5 out of 5 by from Great productI bought thus a few months ago and installed it in a custom 1.5 inch thick plywood plate in my listening couch. I screwed the plate into the wooden structure of the couch all in less than one hour. I drive it with a 90 watt NHT sub amp. The set up provides excellent shake/tactile feel, without adding audible artifact to the overall audio system. Very Happy
Date published: 2015-04-21
Rated 4 out of 5 by from excellent and extra thumpDoes work quite well, and would recommend to anyone who wants to add extra to a movie experience.
Date published: 2015-03-09
Rated 5 out of 5 by from Fast ShippingWorks GreatThis is a test of the emergency broadcast system. In the event of an acutual emergency
Date published: 2014-12-28
Rated 5 out of 5 by from Your prices can't be beat!This is the exact replacement part used in our 10-year old spa audio system.After running all over town trying to find someone to repair the transducer, I decided to check on-line and found newer generation transducers for $400-$600.You folks had the exact unit for under $100 and you included the shipping.Shipped FAST and well packaged with a few bonuses included.I decided to buy a second unit to have on the shelf if the other one goes out and was able to find a few other items to use one of your coupons.Great deal for me and now we can enjoy the audio system in the spa!
Date published: 2014-05-29
Rated 5 out of 5 by from Works Great !I use this for my drum throne kicker. I had a friend make a custom mount for it. This is my second Clark Synthesis Unit That I have purchased. Well worth the money
Date published: 2014-05-07
Rated 5 out of 5 by from Great Product, Better WarrantyBought a pair 2 years ago, poly switches failed a few weeks back. Sent them in for warranty, received new pair less than 2 weeks later.As far as performance, these tranducers are a huge bang for a few bucks. Can't imagine my Home theater without them.
Date published: 2013-10-03
  • 2016-02-09T06:19CST
  • co_hasreviews, tv_0, tr_23
  • loc_en_US, sid_300-861, PRD, sort_mostRecent
I plan on building a riser with four TST209s mounted underneath. My receiver has two LFE outputs and I'm running two subs. I know I can split both of those with a "y". How do I wire the 209s? I have two rows of seats and would run two 209s under each.
Asked by: BobbyG88
Date published: 2015-12-09
do i need an amp or i just plug on speaker out put.and is it better with sub amp.thank you
Asked by: gabriel63
We do recommend using a separate subwoofer amp with these in order to get the most from them. Our SA70 or SA100 would be good choices for one of these transducers.
Date published: 2015-04-27
Hi there. I'm a bassist considering building a small platform for stage monitoring. Trying to find the right power amp - powerful enough, but cheap, tiny, lightweight and mountable to the platform. Can you suggest some options? Tripath? Tx!
Asked by: Kerryg
Date published: 2014-08-25
I want to hook up two TST209 in series in a car, what is an amp you would recommend, also what are the minimal stats you would use.
Asked by: sleeper
I hooked this up to Fosgate 500s (1x125 watts @ 4 Ohms)  with the gain set at half and crossover set at 60 and I just tested playing few songs and the TST209 bottoms out within few seconds and all I get is muffled sounds. Any suggestions?
Asked by: Arsalan
Date published: 2014-08-20
I'm planning to use one of these with an amp that is rates for the following 125 watts RMS x 2 at 4 ohms 250 watts RMS x 2 at 2 ohms 500 watts RMS x 1 at 4 ohms in bridged mode Will there be any issue if I just wire it for 4 ohms @ 125 Watts RMS?
Asked by: ajamils
125 watts at 4 ohms will be perfect for these transducers.
Date published: 2014-08-11
  • 2016-02-09T07:06CST
  • co_hasquestionsanswers, tq_26
  • loc_en_US, sid_300-861, PRD, sort_recentQuestionsFirst
