Clearance Item
243-7846_ALT_0
243-7846_ALT_1
243-7846_ALT_2
243-7846_ALT_3
243-7846_ALT_4
243-7846_ALT_5
Chauvet Scorpion GBC 2.0 DMX Aerial Laser Beam Effect
Brand:| Model: Scorpion GBC 2.0
The Chauvet Scorpion™ GBC 2.0 is an incredibly-bright, color-mixing aerial effect laser great for any event with fog or haze.
  • Separate color control offers solid green, solid blue or combined cyan color mixing
  • The built-in sliding rail system allows multiple units to hang as one
  • Built-in patterns include the ever-popular "laser sky" effect
  • Linkable with other Scorpion™ GVC, Scorpion™ RVM, Scorpion™ RGY and Scorpion™ GBC 2.0 lasers
  • Awesome sound-activated programs dance to the beat of the music
  • Power linking saves time running cables and extension cords
243-7846
Weight: 5.6 lbs.
Chauvet's new Scorpion™ GBC 2.0 is an awesome aerial effect laser with blue and green laser diodes that mix to create cyan. Effect can be programmed to strobe, rotate, roll, morph and zoom into multiple built-in pattern options using ten channels of DMX control. This spectacular show, with a 1 to 36 degree coverage angle, is powered by separate 10mW green and 20mW blue diodes and includes green, blue and/or cyan color options. Patented Fat Beam™ laser technology creates beams that are four times thicker than a standard laser, while the extremely versatile zoom range of 1° - 36° gives you the flexibility to create a mind-blowing laser show.
Specifications: DMX channels: 10 • DMX connectors: 3-pin • Pan & tilt: 43°/39° (variable) • Colors: green, blue and/or cyan • Light source: 532 nm/10 mW green laser diode, 450 nm/20 mW blue diode • Zoom angle: 1° - 36° • Power linking: 37 units @ 120V / 74 units @ 230V • Input voltage: auto-ranging 100~240 VAC • Power and current: 16W, 0.2A @ 120V; 16W, 0.1A @ 230V • Weight: 5.6 lbs. (2.7 kg) • Size: 11" x 8.5" x 7.4" (276 x 215 x 187 mm) • Complies with US FDA CDRH laser safety standards 21 CFR 1040.10 & 1040.11.
  • BrandChauvet
  • ModelScorpion GBC 2.0
  • Part Number243-7846
  • UPC781462209391
  • Product CategoryLaser Lighting
  • Weight5.6 lbs.
View similar products to the Chauvet Scorpion GBC 2.0 DMX Aerial Laser Beam Effect
in the Laser Lighting product category.
Customer projects that include: Chauvet Scorpion GBC 2.0 DMX Aerial Laser Beam Effect
