Clearance Item
243-7878_ALT_0
243-7878_ALT_1
243-7878_ALT_2
243-7878_ALT_3
243-7878_ALT_4
243-7878_ALT_5
243-7878_ALT_6
243-7878_ALT_7
243-7878_ALT_9
Chauvet Scorpion 3D RGB DMX 3-Dimensional Aerial Laser Effect Light
Brand:| Model: SCORPION3DRGB
The Scorpion™ 3D RGB from Chauvet is an innovative multi-colored laser which presents awesome 3-dimensional laser projections. Your audience will be totally floored by the depth and complexity of the 80 available built-in patterns.
  • Red, green and blue lasers mix to create the perfect color combinations
  • Programmable pan, tilt, and zoom with separate X, Y, and Z rolling effects let you easily generate custom laser shows
  • Built-in, sound-activated, automated, and master/slave modes for simple setup and operation
  • Full DMX control for more advanced applications
243-7878
Weight: 5.2 lbs.
Chauvet's groundbreaking new Scorpion™ 3D RGB produces breathtaking aerial effects never before seen from a small, easy-to-use fixture. This innovative graphics laser fills the room with up to 80 selectable 2D, 3D and aerial effects. Extensive parameter control allows for true effect customization, and full DMX control allows you to integrate the Scorpion™ 3D RGB into a larger, more complex lighting presentation.
Specifications: • DMX channels: 18 • DMX connectors: 3-pin • Light source: 655 nm/60 mW red laser diode; 532 nm/30 mW green laser diode; 450 nm/60 mW blue laser diode • Coverage angle: 99° • Power linking: 31 units @ 120V / 52 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60Hz • Power and current: 31W, 0.3A @ 120V 60Hz • Power and current: 35W, 0.2A @ 230V 50Hz • Weight: 5.2 lbs. (2.4 kg) • Size: 8" x 9.4" x 7.5" (204 x 240 x 190 mm).
  • BrandChauvet
  • ModelSCORPION3DRGB
  • Part Number243-7878
  • UPC781462209537
  • Product CategoryLaser Lighting
  • Weight5.2 lbs.
View similar products to the Chauvet Scorpion 3D RGB DMX 3-Dimensional Aerial Laser Effect Light
in the Laser Lighting product category.
Customer projects that include: Chauvet Scorpion 3D RGB DMX 3-Dimensional Aerial Laser Effect Light
