Clearance Item
243-7778_ALT_0
243-7778_ALT_1
243-7778_ALT_2
243-7778_ALT_3
243-7778_ALT_4
243-7778_ALT_5
243-7778_ALT_6
243-7778_ALT_7
243-7778_ALT_8
243-7778_ALT_9
Chauvet Rotosphere LED Mirror Ball Simulator Effect Light
Brand:| Model: ROTOSPHERELED
The Rotosphere is a mirror ball simulator by Chauvet with five high-powered tri-color LEDs.
  • Easy-to-use, mirror ball simulator with five, high-powered tri-color LEDs
  • Evenly spaced lenses optimize output and reduce dead spots
  • Adjustable speed of rotation and extremely smooth movement let you match the mood of the music
  • Use the included bracket to mount it on a truss, or use it as a striking tabletop
  • Blankets the entire room in multicolored beams
  • User-selectable colors and speed of rotation in stand-alone allow customized looks without a DMX controller
  • Power linking saves time running cables and extension cords
243-7778
Weight: 7.1 lbs.
Rotosphere™ LED is a mirror ball simulator that is easy to use and DMX controllable. Powered by five tri-color LEDs, this fixture blankets the entire room in multi-colored beams with smooth and continuous 360° rotation. Evenly spaced lenses optimize output and reduce dead spots while adjustable rotation speed lets you match the mood of the music.
Specifications: • DMX channels: 4 • DMX connectors: 3-pin • Light source: Five x 3 watt (350 mA x 3) tri-color LEDs 50,000 hrs • Coverage angle: 360° • Power linking: 20 units @ 120V / 40 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 58W, 0.5A @ 120V 60 Hz • Power and current: 65W, 0.3A @ 230V 50 Hz • Dimensions: 12.1" x 12.1" x 17.4" • Weight: 7.1 lbs.
  • DMX-ControllableNo
  • BrandChauvet
  • ModelROTOSPHERELED
  • Part Number243-7778
  • UPC781462207519
  • Product CategoryClub & DJ Effects Lighting
  • Weight7.1 lbs.
View similar products to the Chauvet Rotosphere LED Mirror Ball Simulator Effect Light
in the Club & DJ Effects Lighting product category.
Customer projects that include: Chauvet Rotosphere LED Mirror Ball Simulator Effect Light
