CHAUVET Professional COLORdash Accent Compact DMX RGBW LED Wash Light
Brand:|Model: COLORdash Accent|Part # 243-7080
The COLORdash™ Accent takes lighting in confined spaces to a new level, thanks to 7 high power, 1-watt LEDs and its diminutive size. Robust, yet sleek in appearance, its cast aluminum housing helps dissipate heat. Control is via DMX or on-board dip switches.
  • 3, 4, or 9-channel ultra compact RGBW LED wash light
  • Operating modes: 3-ch RGB control, 4-ch RGBW control, 9-ch RGBW, dimmer, macro, strobe
  • RGBW color mixing with or without DMX control
  • Built-in automated programs via master/slave or DMX
  • Double-bracket yoke doubles as floor stand
The COLORdash™ Accent takes lighting in confined spaces to a new level, thanks to seven high power, 1-watt LEDs and its diminutive size. At just under 7" long and 3" in diameter, this 1.5 lb light mounts just about anywhere. Robust, yet sleek in appearance, its cast aluminum housing helps dissipate heat. Control is via DMX or on-board dip switches capable of static colors or built-in programs.
Specifications: • 18° optics • Beam angle: 20° • Field angle: 37.5° • Lux: 926 @ 1m, 240 @ 2m • Light source: seven 1W LEDs rated for 50,000 hours (2 x 350 mA red, 2 x 350 mA green, 2 x 350 mA blue, 1 x 350 mA white) • Power and current: 120V, 60 Hz, 10W, 0.1A (operating); 230V, 50 Hz, 10W, 0.1A (operating) • AC power: auto-ranging 100~240 VAC, 50/60 Hz • Weight: 1.5 lbs. (0.6 kg) • Size: 6.9" x 4.3" x 2.5" (174 x 108 x 65 mm).
  • Light TypeMicro/Compact
  • DMX-ControllableYes
  • BrandCHAUVET Professional
  • ModelCOLORdash Accent
  • Part Number243-7080
  • UPC781462203825
  • Product CategoryWash Lights / Stage Lighting
  • Weight1.5 lbs.
View similar products to the CHAUVET Professional COLORdash Accent Compact DMX RGBW LED Wash Light
in the Wash Lights / Stage Lighting product category.
