243-7686_ALT_0
243-7686_ALT_1
243-7686_ALT_2
243-7686_ALT_3
243-7686_ALT_4
243-7686_ALT_5
243-7686_ALT_6
243-7686_ALT_7
Chauvet Intimidator Spot LED 250 DMX Moving Yoke Light
Brand:| Model: INTIMSPOTLED250
The Intimidatorâ„¢ Spot LED 250 is a LED-powered moving head that provides user-selectable pan and tilt ranges to display light exactly where you want it. Provides a 3-facet rotating prism to cover a large area, as well as an electronic dimmer for super-smooth LED fading.
  • LED-powered moving head packed with features to benefit any event or installation
  • 3-facet prism splits the beam for great effects and to cover a larger area
  • Easy-access gobo door allows for quick gobo changes without opening the fixture
  • Electronic dimmer allows super-smooth LED fading
  • User-selectable pan and tilt ranges keep the light where you want it
  • Built-in effect macros and move-in-black feature minimizes programming time
  • Power linking saves time running cables and extension cords
243-7686
Weight: 16.85 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$839.99
You Save28%
$599.99
Part # 243-7686
Feature packed, the Intimidator Spot 40 watt LED moving head yoke features a three-facet rotating prism that splits the beam for great effects and to cover a larger area. Easy access gobo door allows for quick gobo changes and an electronic dimmer allows for super-smooth LED fading. Individual reset of pan/tilt, color, gobo and prism allows the show to continue no matter what happens. Awesome sound-activated programs dance to the beat of the music. Easy access to built-in automated programs generate a synchronized show in master/slave mode.
Specifications: • DMX channels: 8 or 13 • DMX connectors: 3-pin • Pan & tilt: 540° / 270° • Pan & tilt ranges: 540°, 360°, 180° pan / 270°, 180°, 90° tilt • Colors: 8 + white, split colors, continuous scroll at variable speeds • Gobos: 7  rotating, interchangeable, indexing, slot-n-lock, gobo shake, continuous scroll at variable speeds • Gobo size: 24 mm outside, 20 mm image, 1.1 mm max thickness • Light source: one white 40W (14.4 A) LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Beam angle: 17° • Illuminance: 5,970 lux @ 2m • Power linking: 6 units @ 120 V / 11 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 150 watts, 1.3A @ 120V 60 Hz • Power and current: 157 watts, 0.7A @ 230V 50 Hz • Dimensions: 9.3" x 8.1" x 11.3" (236 x 205 x 287 mm) • Weight: 12.6 lbs. (5.7 kg) • Approvals: CE.
  • BrandChauvet
  • ModelINTIMSPOTLED250
  • Part Number243-7686
  • UPC781462208141
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight16.85 lbs.
View similar products to the Chauvet Intimidator Spot LED 250 DMX Moving Yoke Light
in the Moving Yoke & Scanner Intelligent Lighting product category.
Customer projects that include: Chauvet Intimidator Spot LED 250 DMX Moving Yoke Light
