243-7860_ALT_0
243-7860_ALT_1
243-7860_ALT_2
243-7860_ALT_3
243-7860_ALT_4
243-7860_ALT_5
243-7860_ALT_6
243-7860_ALT_7
Chauvet Intimidator Beam LED 350 DMX Moving Head Spotlight with Gobos
Brand:| Model: INTIMBEAMLED350
The Intimidatorâ„¢ Beam LED 350 is a feature-packed moving head fixture fitted with a 75W LED to produce bright, long-throw effects with tight, concentrated beam angles.
  • Bright, tight beam moving head fixture
  • 8 colors plus white; 5 gobo slots
  • User-selectable pan and tilt ranges
  • Built-in automated and sound-activated programs
243-7860
Weight: 22 lbs.
ORDER TODAY
Ships in 3-10 business days
List Price$1,259.99
You Save28%
$899.99
Part # 243-7860
Chauvet's Intimidator™ Beam LED 350 is designed to produce a bright, super-tight (only 4 degree) beam for your stage show. Complete with 8-position color wheel, 5-position fixed gobo wheel with an animation effect, and a 3-facet prism, this light cuts through haze with lightning-fast speed, creating a brilliant shaft of light and very defined aerial effects. This fixture can also serve dual roles; by utilizing the frost filter you can attain an effective wash effect as well.
You can create spectacular aerial light shows using extremely fast pan and tilt speeds, and put the beam precisely where you want it with user-selectable pan and tilt ranges. The Intimidator™ Spot LED 350 works in master/slave mode to coordinate multiple units for a very impressive display. You'll minimize programming time with built-in movement macros and move-in-black features, sound-activated automatic programs which will dance to the beat of your music, and you'll save time running cables and extension cords by power linking multiple units.
Specifications: • DMX channels: 8 or 14 • DMX connectors: 3-pin • Pan and tilt: 540°/270° • Pan and tilt ranges: 540°, 360°, 180° pan; 270°, 180°, 90° tilt • Colors: 8 + white, split colors, continuous scroll at variable speeds • Gobos: 5 + open, animation effect, continuous scroll at variable speeds • Light source: one white 75W (17A) LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Beam angle: 4° • Illuminance: 139,200 lux @ 2m • Power linking: 3 units @ 120V; 7 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 258W, 2.1A @ 120V 60 Hz • Power and current: 269W, 1.2A @ 230V 50 Hz • Weight: 22 lbs. (9.8 kg) • Size: 11.3" x 13.4" x 18.5" (287 x 340 x 470 mm).
  • BrandChauvet
  • ModelINTIMBEAMLED350
  • Part Number243-7860
  • UPC781462209179
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight22 lbs.
View similar products to the Chauvet Intimidator Beam LED 350 DMX Moving Head Spotlight with Gobos
in the Moving Yoke & Scanner Intelligent Lighting product category.
Customer projects that include: Chauvet Intimidator Beam LED 350 DMX Moving Head Spotlight with Gobos
