Clearance Item
243-7684_ALT_0
243-7684_ALT_1
243-7684_ALT_2
243-7684_ALT_3
243-7684_ALT_4
243-7684_ALT_5
243-7684_ALT_6
243-7684_ALT_7
Chauvet Intimidator Barrel LED 300 DMX LED Barrel Effect Light
Brand:| Model: INTIMBARREL300
The Intimidatorâ„¢ Barrel LED 300 by Chauvet includes seven interchangeable, rotating gobos and eight separate, saturated colors for increased design flexibility and effects.
  • Bright and compact LED barrel with tons of features to enhance any show
  • Interchangeable, rotating gobos plus separate, saturated colors allow extra flexibility and effects
  • Built-in movement macros and move-in-black features minimize programming time
  • Motorized focus allows the gobos to be crisp when projected at almost any distance
  • Electronic dimming and strobe features deliver silent operation with no moving parts
  • Crisp, 3-sided prism duplicates the beam for great effects and to cover a larger area
  • Individual reset of pan/tilt, color, gobo, prism and focus allows the show to continue no matter what happens
243-7684
Weight: 14.2 lbs.
This bright and compact LED powered barrel scanner comes with tons of features to enhance any show. Motorized focus allows for crisp gobos when projected from almost any distance. High-frequency LED dimming allows for flicker-free video operation. Sound-activated programs dance to the beat of the music. Easy-access to built-in automated programs generate a synchronized show in master/slave mode. Power linking saves time running cables and extension cords (US version only).
Specifications: • DMX channels: 8 or 11 • DMX connectors: 3-pin • Pan and tilt: 180° / 360° • Colors: 8 + white, split colors, continuous scroll at variable speeds • Gobos: 7 + open, rotating, slot-n-lock, continuous scroll at variable speeds • Gobo size: 23.8 mm outside, 20.9 mm image, 2 mm max thickness • Light source: one white 60W (15 A) LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Illuminance: 1,736 lux @ 2 m • Power linking: 3 units @ 120V / 7 units @ 230V • Input voltage: Switchable 120/230 VAC 50/60 Hz • Power and current: 240 watts, 2A @ 120V 60 Hz • Power and current: 240 watts, 1A @ 230V 50 Hz • Dimensions: 20.5" x 10" x 6.7" (521 x 255 x 171 mm) • Weight: 14.2 lbs. (6.4 kg) • Approvals: CE, MET.
  • DMX-ControllableYes
  • BrandChauvet
  • ModelINTIMBARREL300
  • Part Number243-7684
  • UPC781462208257
  • Product CategoryClub & DJ Effects Lighting
  • Weight14.2 lbs.
View similar products to the Chauvet Intimidator Barrel LED 300 DMX LED Barrel Effect Light
in the Club & DJ Effects Lighting product category.
Customer projects that include: Chauvet Intimidator Barrel LED 300 DMX LED Barrel Effect Light
