Clearance Item
243-7598_ALT_0
243-7598_ALT_1
Chauvet Hurricane Haze 2 Professional 2-Ch DMX Haze Effect
Brand:| Model: Hurricane Haze 2
The Hurricane Haze 2 by Chauvet has an adjustable blower output speed and direction allowing you to control exactly where you want the haze.
  • Water-based haze machine that creates a thin atmosphere to enhance any light show
  • Runs continuously and never stops to reheat so the haze is always ready to go
  • Haze output and blower speeds are adjustable via stand-alone operation (no controller needed)
  • User-adjustable output angle ensures the haze goes where it’s needed
  • Low-fluid indicator automatically turns off the machine when the tank is empty
  • Includes wired, timer remote with storage compartment for easy transportation
243-7598
Weight: 21.85 lbs.
The water based Hurricane Haze 2 machine runs with a continuous output so you can ensure the machine will never stop to reheat. The low fluid indicator gives a warning before automatically shutting down when empty. Control is via DMX or the included wired, timer remote which stores conveniently in the fixture.
Specifications: • DMX channels: 2 • Tank capacity: 0.9 gal (3.3L) • Remote length: 15 ft. (4.6 m) • Heat up time: 5 min • Output: 1,200 cfm (34 m³/min.) • Fluid consumption: 21 ml/min. • Power and current: 120V, 60 Hz: 504 watts, 4.1A • AC power: 115V/60 Hz • Weight: 18.7 lbs. (8.5 kg) • Dimensions: 11.1" x 10.5" x 14" (282 x 267 x 356 mm).
  • BrandChauvet
  • ModelHurricane Haze 2
  • Part Number243-7598
  • UPC781462206093
  • Product CategoryFoggers, Hazers & Bubble Machines
  • Weight21.85 lbs.
View similar products to the Chauvet Hurricane Haze 2 Professional 2-Ch DMX Haze Effect
in the Foggers, Hazers & Bubble Machines product category.
Chauvet Hurricane Haze 2 Professional 2-Ch DMX Haze Effect is rated 1.0 out of 5 by 1.
Rated 1 out of 5 by from Great output / POOR QualityI own two of these hazers used in a nightclub environment. Output is great... However there is a spring in the fluid pump that breaks about every two months. Box it up and send it in for repairs, takes about a month or so. Back in service, and the thing breaks religiously within two months again. I've attempted to buy the springs from Chauvet to make the repair myself. But they refuse to sell them.
Date published: 2013-01-15
Customer projects that include: Chauvet Hurricane Haze 2 Professional 2-Ch DMX Haze Effect
