Clearance Item
243-7914_ALT_0
243-7914_ALT_1
243-7914_ALT_2
243-7914_ALT_3
243-7914_ALT_4
243-7914_ALT_5
243-7914_ALT_6
Chauvet Hive DMX LED 6-Beam Effects Light
Brand:| Model: HIVE
The Hiveā„¢ emits bold, multicolored beams designed for any mobile application in need of effects. It floods any size venue with tight, focused beams using 6 large-diameter lenses.
  • Bright multicolored beam effect from 18 powerful red, green, and blue LEDs
  • Create an endless combination of customized effects with individual pod control via DMX
  • Sound-activated programs dance to the beat of your music
  • Generate synchronized shows in master/slave mode with easy access to built-in automated programs
243-7914
Weight: 10 lbs.
Chauvet's Hive™ is an exciting new effects light that emits sharp, brightly colored beams to give any mobile application that "rock star" look. High-powered red, green and blue LEDs project tight, concentrated beams from six fixed-angle lenses. Create customized looks in DMX mode, or allow built-in, automated and sound-active programs to work the show. Pair it with a fog or haze machine to maximize overall effectiveness, and create eye-catching, mid-air effects.
Specifications: • DMX channels: 3 or 20 • DMX connectors: 3-pin • Light source: 18 (6 red, 6 green, 6 blue) 3W (730mA) LEDs rated for 50,000 hours • Coverage angle: 44° • Power linking: 5 units @ 120V; 10 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 167W, 1.4A @ 120V 60 Hz • Power and current: 174W, 0.7A @ 230V 50 Hz • Weight: 9.2 lbs. (4.2 kg) • Size: 9.4" x 13" x 8.8"  (240 x 330 x 225 mm).
  • DMX-ControllableYes
  • BrandChauvet
  • ModelHIVE
  • Part Number243-7914
  • UPC781462210359
  • Product CategoryClub & DJ Effects Lighting
  • Weight10 lbs.
View similar products to the Chauvet Hive DMX LED 6-Beam Effects Light
in the Club & DJ Effects Lighting product category.
Customer projects that include: Chauvet Hive DMX LED 6-Beam Effects Light
