Clearance Item
243-7066_ALT_0
243-7066_ALT_1
243-7066_ALT_2
Chauvet DMX-800 Constellation DMX Centerpiece Effect Light
Brand:| Model: DMX-800
Constellation™ is a stunning DMX-controllable centerpiece with six scanning heads that fill dance floors with sweeping beams and gobos. An HMI 575W lamp powers the unit.
  • 13 or 19-channel DMX-512 centerpiece
  • Operating mode: 13-channel: control pan and tilt in pairs
  • Operating mode: 19-channel: control pan and tilt separately for each head
  • Pan: 180° / tilt: 90° (each mirror)
  • Pan/tilt control of each mirror
  • Variable strobe/shutter/dimmer
  • 7 glass, rotating gobos + open on each wheel
243-7066
Weight: 99.2 lbs.
Constellation™ is a stunning DMX-controllable centerpiece with six scanning heads that fill dance floors with sweeping beams and gobos. An HMI 575W lamp powers the unit. The six scanning heads cover up to a 73-degree beam spread. Each head has a gobo wheel fitted with 7 dichroic glass gobos plus an open slot. The entire unit can dim, strobe or be blacked out using the shutter. And, conveniently, it can also be reset remotely. Constellation™ runs in either a 13 or 19-channel DMX configuration but also performs well in stand-alone or sound-activated mode.
Specifications: • Beam angle: 12° (each beam), 73° (entire unit) • Lux: 105,276 @ 1m • Light source: HMI575/GS 575W 6000°K  rated for 1,000 hours • Power and current: 120V 60 Hz; 637W, 6.4A operating, 10.2A inrush, PF 0.85 • AC power: switchable 110V/230V, 50/60 Hz • Weight: 99.2 lbs. (45 kg) • Size: 33.5" x 31.5" x 11.8" (850 x 800 x 300 mm).
  • DMX-ControllableYes
  • BrandChauvet
  • ModelDMX-800
  • Part Number243-7066
  • UPC781462202347
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight99.2 lbs.
View similar products to the Chauvet DMX-800 Constellation DMX Centerpiece Effect Light
in the Moving Yoke & Scanner Intelligent Lighting product category.
Customer projects that include: Chauvet DMX-800 Constellation DMX Centerpiece Effect Light
