Chauvet DJ Sweeper LED Tri-Color LED Lighting Effect DMX
Brand:|Part # 243-7674
Chauvet's Sweeper LED is a compact, multi-beam lighting effect that utilizes tri-color LEDs for amazing color chases and sequences.
  • Compact, multi-beam effect that utilizes tri-color LEDs for amazing color chases and sequences
  • Individual pod control allows the you to create an endless combination of customized effects
  • Works in master/slave with the 6SPOT™ for large, coordinated light shows
  • Power link up to 20 units which saves time running cables and extension cords
  • Awesome sound-activated programs dance to the beat of the music
  • Easy-access to built-in automated programs generate a synchronized show in master/slave mode
Create an endless combination of customized lighting effects with with the Sweeper LED by Chauvet. It's powered by 6 high power tri-color LEDs. Unit has individual control of each pod allowing for complex and unique chasing effects. Linkable with the 6SPOT™, the units can combine for large coordinated shows. Save time running cables and extension cords by power linking up to 20 units.
Specifications: • DMX channels: 8 • Light source: Six 3W (375mA x3) tri-color LEDs 50,000 hrs • Strobe rate: 0-30 Hz • Beam angle: 11° (per light) • Coverage angle: 76° • Lux: 814 @ 1m (per light) • Power and current: 120V, 60 Hz: 30 watts, 0.4A operating; 230V, 50 Hz: 30 watts, 0.5A operating • AC power: Auto-switching 100~240VAC, 50/60 Hz • Power linking: max 20 units @ 120V (see manual for details) • Weight: 5 lbs. (2.2 kg) • Dimensions: 14.8" x 7.5" x 6.3" (375 x 190 x 160 mm).
  • DMX-ControllableYes
  • BrandChauvet DJ
  • Part Number243-7674
  • UPC781462206345
  • Product CategoryClub & DJ Effects Lighting
  • Weight6.65 lbs.
View similar products to the Chauvet DJ Sweeper LED Tri-Color LED Lighting Effect DMX
in the Club & DJ Effects Lighting product category.
