Chauvet DJ Nimbus Professional Dry Ice Machine
Brand:|Model: NIMBUS|Part # 243-7722
The Nimbus is a powerful dry ice machine that heats enough water to create fog from 10 lbs. of dry ice to provide 6 minutes of run time.
ORDER TODAY
Ships in 7-10 Business Days
List Price$1,399.99
You Save29%
$999.99
Part # 243-7722
  • Professional dry ice machine creates thick, white fog that hugs the floor
  • Simple, plug-n-play operation quickly heats water to its optimal operating temperature
  • Second heating element heats the water in half the time
  • Adjustable, multi-level control handle manipulates the output and flow
  • Low-water and temperature sensors automatically shut off heaters for added safety
Nimbus™ is a professional dry ice machine which produces thick, white fog that hugs the floor and dissipates without rising. Output and flow are easily controlled, thanks to an adjustable multi-level control arm. Dual heaters allow for faster heat-up and recycle times. A low water sensor increases safety.
Specifications: • Input voltage: 120V 60 Hz • Power and current (single element): 1,500 watts, 12.6A  • Power and current (dual element): 3,000 watts, 25.2A • Tank capacity: 4.5 gal • Heat-up time (single element): 50 min • Heat-up time (dual element): 30 min • Average runtime: 6 min • Reheat time (single element): 30 min • Reheat time (dual element): 15 min • Dry ice capacity: 10 lbs. • Max water temperature: 175° F • Dimensions: 20" x 18" x 19" • Weight (empty): 28.6 lbs. • Weight (full): 75 lbs. • Approvals: CE, MET.
  • BrandChauvet DJ
  • ModelNIMBUS
  • Part Number243-7722
  • UPC781462207816
  • Product CategoryFoggers, Hazers & Bubble Machines
    (1 Reviews)
  • Weight28.6 lbs.
View similar products to the Chauvet DJ Nimbus Professional Dry Ice Machine
in the Foggers, Hazers & Bubble Machines product category.
