Chauvet DJ MotionFacade LED Compliments MotionDrape with Bag
Brand:|Model: MOTIONFACADELED|Part # 243-7714
Chauvet's MotionFacade LED drape is made up of 66 tri-color LEDs matrixed across a 3.3 ft. x 6.5 ft. backdrop, creating over 30 animated effects!
ORDER TODAY
Ships in 7-10 Business Days
List Price$339.99
You Save26%
$249.99
Part # 243-7714
  • 4 ft. x 6.6 ft. (1.22 x 2 m) LED DJ front-board skirt with motion graphics, perfect for DJ, bands, and clubs
  • High output tri-color SMD LEDs
  • Replaces the conventional front board by attaching directly to your coffin or rack with sewn in Velcro™ fasteners
  • Features the same 30 graphic effects as the MotionDrape™ LED to create a synchronized show
  • Fantastic multi-color rain effect, and simulated equalizer pattern included
  • Equipped with a sound-activation mode to trigger your effects
  • Choose and run your favorite program with or without a DMX-512 console
MotionFaçade™ LED is the perfect companion to the MotionDrape™ LED. At 3.3 ft. by 6.5 ft., the MotionFaçade™ LED makes a perfect front board for a DJ. 66 tri-color SMD LEDs power 30 different effects. The façade can easily run in conjunction with the MotionDrape™ LED or on its own via the included controller or DMX. The drape has 8 channels of DMX control to customize your show and full RGB color mixing capability to match your event's color scheme. Master dimmer gives you full control over output.
Grommets for easy truss mounting and various stand applications. Certified fire retardant material (NFPA). Free carry bag makes storage and transport a breeze.
Specifications: • DMX channels: 8 • DMX connectors: 3-pin • Light source: 66 tri-color SMD LEDs • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 21W, 0.2A @ 120V 60 Hz • Power and current: 23W, 0.1A @ 230V 50 Hz • Dimensions (drape): 4 ft. x 6.6 ft. (1.22 x 2 m) • Dimensions (controller): 5.3" x 9.6" x 2" (135 x 243 x 50 mm) • Weight (drape): 3.9 lbs. (1.7 kg) • Weight (controller): 1.8 lbs. (0.8 kg) • Approvals: CE, MET
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelMOTIONFACADELED
  • Part Number243-7714
  • UPC781462207465
  • Product CategoryClub & DJ Effects Lighting
  • Weight5.7 lbs.
View similar products to the Chauvet DJ MotionFacade LED Compliments MotionDrape with Bag
in the Club & DJ Effects Lighting product category.
