Chauvet DJ Intimidator Wash LED 150 DMX Moving Yoke Light
Brand:|Model: INTIMWASHLED150|Part # 243-7690
The Intimidator Wash LED 150 by Chauvet has quad-color LEDs and high-quality optics that generate bright color combinations.
  • Bright and compact LED moving head wash, perfect for mobile applications and permanent installations
  • Quad-color LED and high-quality optics generate bright color combinations
  • Fast and precise movements energize the dance floor
  • Smooth dimming and vibrant strobing add class and energy to the light show
  • Built-in movement macros and move-in-black features minimize programming time
  • Power linking saves time running cables and extension cords
  • On-board sound-activated programs let you concentrate on the show, not the programming
The Intimidator Wash LED 150 is the wash compliment to the Intimidator Spot LED 150. Fitted with a powerful 40 watt, quad-color (RGBW) LED, this little powerhouse will wash the venue in any color you choose. Full RGBW color mixing is available to the user through DMX or simply let the auto and sound-active programs do the work for you. Easy access to built-in automated programs to generate a synchronized show in master/slave mode.
Specifications: • DMX channels: 6 or 15 • DMX connectors: 3-pin • Pan & tilt: 540° / 270° • Pan & tilt ranges: 180°, 360°, 540° pan / 90°, 180°, 270° tilt • Colors: RGBW color mixing • Light source: One 40W (1.1A x 4) quad-color RGBW LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Beam angle: 22° • Field angle: 45° • Illuminance: 750 lux @ 2m • Power linking: 6 units @ 120V / 12 units @ 230V • Input voltage: auto-ranging 100-240 VAC 50/60 Hz • Power and current: 110 watts, 0.9A @ 120V 60 Hz • Power and current: 116 watts, 0.5A @ 230V 50 Hz • Weight: 6.9 lbs. (3.2 kg) • Dimensions: 8.3" x 8.2" x 10.5" (211 x 207 x 267 mm) • Approvals: CE, MET.
  • BrandChauvet DJ
  • ModelINTIMWASHLED150
  • Part Number243-7690
  • UPC781462206925
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight6.9 lbs.
View similar products to the Chauvet DJ Intimidator Wash LED 150 DMX Moving Yoke Light
in the Moving Yoke & Scanner Intelligent Lighting product category.
