Chauvet DJ Intimidator Spot XYZ DMX LED Moving Yoke Light
Brand:|Part # 243-7072
The Intimidator™ Spot XYZ moving yoke uses a third axis of motion to create unique positions and effects. This feature-packed fixture includes a high power, 60 watt LED, 7-color + white color wheel, and rotating gobo wheel.
  • 11 or 16-channel DMX-512 moving yoke
  • Pan 1: 540° / pan 2: 540° / tilt: 540°
  • Color wheel: 7 colors + white, split colors, rainbow color spin at variable speeds
  • Rotating gobo wheel with gobo shake, 7 interchangeable gobos + open, 5 metal, 2 glass installed
  • 3-facet prism
  • Variable electronic shutter (for strobing)
  • Variable motorized focus
The Intimidator™ Spot XYZ moving yoke uses a third axis of motion to create unique positions and effects. This feature-packed fixture includes a high power, 60 watt LED, 7-color + white color wheel, and rotating gobo wheel with gobo shake—7 interchangeable gobos + open (5 metal, 2 glass installed). It also offers remote focus and a 3-facet prism with output similar to a 250 watt light source.
Specifications: • Rotating gobos: 23.8 mm outside, 20 mm image, 2 mm max thickness • Beam angle: 17° • Lux: 17,300 @ 1m • Light source: 1 (white) LED 50,000 hrs. • Power and current: 120V, 60 Hz: 118W, 1.6A operating, 2.6A inrush • AC power: Auto-switching 100~240V, 50/60 Hz • Weight: 18.4 lbs. (8.3 kg) • Size: 11.6" x 10.9" x 16.9" (294 x 276 x 429 mm).
  • BrandChauvet DJ
  • Part Number243-7072
  • UPC781462204037
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight18.4 lbs.
View similar products to the Chauvet DJ Intimidator Spot XYZ DMX LED Moving Yoke Light
in the Moving Yoke & Scanner Intelligent Lighting product category.
