Chauvet DJ Intimidator Spot LED 450 DMX Moving Head Spotlight with Gobos
Brand:|Model: INTIMSPOTLED450|Part # 243-7858
The Intimidator™ Spot LED 450 is a very bright moving head fixture fitted with 180 watts of LED power for large-scale events. It is capable of sharp, crisp projections at almost any distance using the motorized focus.
  • Full text readout on a high-contrast LCD screen
  • Quickly change gobos using the easy-access gobo door
  • User-selectable pan and tilt ranges
  • Built-in automated and sound-activated programs
Chauvet's Intimidator™ Spot LED 450 takes advantage of three 60-watt white LEDs and super sharp optics to produce a powerful and impressive output which will really punch through ambient lighting. This feature-packed moving head includes a motorized focus to project crisp rotating gobos from most distances. A 3-facet rotating prism splits the beam for multiple effects and a larger coverage area, while easily accessible, interchangeable gobos allow for custom looks.
You'll enjoy simple menu navigation and a full text readout with the high-contrast LCD screen, and smooth LED fading with the electronic dimmer. You can project light precisely where you want it with user-selectable pan and tilt ranges, and also minimize programming time with the built-in effect macros and move-in-black feature. Using the built-in, automated and sound-activated programs, you can have this fixture up and running in no time flat, or take full control in DMX or master/slave mode for as much customization as you want.
Specifications: • DMX channels: 8 or 14 • DMX connectors: 3-pin • Pan and tilt: 540°/270° • Pan and tilt ranges: 540°, 360°, 180° pan; 270°, 180°, 90° tilt • Colors: 7 + white, split colors, continuous scroll at variable speeds • Gobos: 7 + open, rotating, interchangeable, indexing, slot-n-lock, continuous scroll at variable speeds • Gobo size: 26.75 mm outside, 23 mm image, 3mm max thickness • Light source: three white 60 watt (16A) LEDs rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Beam angle: 19° • Illuminance: 23,680 lux @ 2m • Input voltage: auto-ranging 100~240 VAC, 50/60 Hz • Power and current: 400W, 3.3A @ 120V 60 Hz; 395W, 1.7A @ 230V 50 Hz • Weight: 43.6 lbs. (19.8 kg) • Size: 16.6" x 11.9" x 24" (423 x 303 x 610 mm).
  • BrandChauvet DJ
  • ModelINTIMSPOTLED450
  • Part Number243-7858
  • UPC781462209599
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight44 lbs.
View similar products to the Chauvet DJ Intimidator Spot LED 450 DMX Moving Head Spotlight with Gobos
in the Moving Yoke & Scanner Intelligent Lighting product category.
