CHAUVET DJ Intimidator Spot LED 350 DMX Moving Yoke Light
Brand:|Model: INTIMSPOTLED350|Part # 243-7688
The Intimidator™ Spot 350 by Chauvet is the most powerful LED spot in the Intimidator™ line with only 75 watt LEDs.
  • Feature packed, 75 W LED moving head spot
  • Motorized focus allows the rotating gobos to be crisp when projected at most distances
  • 3-facet rotating prism splits the beam for great effects and to cover a larger area
  • Easy-access gobo door allows for quick gobo changes without opening the fixture
  • Electronic dimmer allows super-smooth LED fading
  • Manual zoom decreases beam angle by 5° to project farther
  • User-selectable pan and tilt ranges keep the light where you want it
Chauvet® is proud to announce the latest addition to the Intimidator™ family of moving lights. Intimidator™ Spot 350 is the most powerful LED spot in the Intimidator™ line. A 75 watt LED combined with superior optics makes this fixture considerably brighter than most 90 watt LED fixtures currently on the market. This feature packed moving head features a motorized focus for crisp, rotating gobos when projected from most distances. A three-facet rotating prism splits the beam for great effects and to cover a larger area while interchangeable gobos allow for custom looks.
Built-in effect macros and move-in-black feature minimizes programming time. Power linking saves valuable time running cables and extension cords. Individual reset of pan/tilt, color, gobo, prism and focus allows the show to continue no matter what happens. Sound-activated programs dance to the beat of the music. Easy access to built-in automated programs generate a synchronized show in master/slave mode.
Specifications: • DMX channels: 8 or 14 • DMX connectors: 3-pin • Pan & tilt: 540°/270° • Pan & tilt ranges: 540°, 360°, 180° pan / 270°, 180°, 90° tilt • Colors: 8 + white, split colors, continuous scroll at variable speeds • Gobos: 7, rotating, interchangeable, indexing, slot-n-lock, gobo shake, continuous scroll at variable speeds • Gobo size: 24 mm outside, 20 mm image, 1.1 mm max thickness • Light source: one white 75W (17 A) LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Zoom angle: 12°- 17° • Illuminance (12°): 9,490 lux @ 2m • Power linking: 3 units @ 120V / 7 units @ 230V • Input voltage: auto-ranging 100-240 VAC 50/60 Hz • Power and current: 272 watts, 2.2A @ 120V 60 Hz • Power and current: 285 watts, 1.2A @ 230V 50 Hz • Dimensions: 10.6" x 13.4" x 15.4" (268 x 340 x 392 mm) • Weight: 22.7 lbs. (10.3 kg) • Approvals: CE.
  • BrandCHAUVET DJ
  • ModelINTIMSPOTLED350
  • Part Number243-7688
  • UPC781462208158
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight22.7 lbs.
View similar products to the CHAUVET DJ Intimidator Spot LED 350 DMX Moving Yoke Light
in the Moving Yoke & Scanner Intelligent Lighting product category.
