243-7862_ALT_0
243-7862_ALT_1
243-7862_ALT_2
243-7862_ALT_3
243-7862_ALT_4
CHAUVET DJ Intimidator Spot Duo DMX LED Double Moving Head Fixture
Brand:| Model: INTIMSPOTDUO
With the Intimidatorâ„¢ Spot Duo, you get two powerful Intimidatorâ„¢ moving heads pre-mounted on a single bar that mounts to truss or tripod, or simply sits on the floor. This piece punches far above its weight class, offering impressive features and ease of use in one compact and convenient package.
  • Two powerful Intimidatorâ„¢ moving heads pre-mounted on a single bar
  • Easily mounts to truss or tripod, or sits on the floor
  • Add the look of a programmed show using 16 built-in master/slave programs
  • Save time running cables and extension cords by power linking multiple units
243-7862
Weight: 27.0000 lbs.
ORDER TODAY
Ships in 3-10 business days
List Price$779.99
You Save26%
$579.99
Part # 243-7862
Chauvet's Intimidator™ Spot Duo features not only one, but two fully and independently controllable moving heads mounted on an easy-to-rig bar. Slide it onto a tripod, clamp it to truss or sit it on the floor. It's your choice, Chauvet has made it easy. This high performance duo is linkable with up to four other units to create eye-catching synchronized shows. Independent color and gobo wheels create numerous projections and mid-air effects, while DMX control allows for independent control of each head.
You'll reduce programming time with master/slave programs which include an offset feature. You'll save time running cables and extension cords by power linking multiple units. And you'll enjoy the simplicity of multiple control options including rich automated and sound-active programs, as well as master/slave. DMX mode gives you full control over each head individually, so of course, you can take your control to whatever level you desire.
Specifications: • DMX channels: 10, 17 or 20 • DMX connectors: 3-pin • Pan & tilt: 360° / 270° (per head) • Pan & tilt ranges: 180°, 360° pan; 90°, 180°, 270° tilt • Colors: 7 + white, split colors, continuous scroll at variable speeds (per head) • Gobos: 9 + open, continuous scroll at variable speeds (per head) • Light source: one white 10 watt (2.8A) LED rated for 50,000 hours (per head) • Strobe rate: 0 - 17 Hz • Beam angle: 6° (per head) • Illuminance: 10,900 @ 2m (per head) • Fits tripod sizes: 1.4" to 2" (36 mm to 50 mm) • Power linking: 9 units @ 120V / 17 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 98W, 0.8A @ 120V 60 Hz; 104W, 0.4A @ 230V 50 Hz • Weight: 18.4 lbs. (8.4 kg) • Size: 21" x 7.4" x 14.4" (540 x 187 x 365 mm).
  • BrandCHAUVET DJ
  • ModelINTIMSPOTDUO
  • Part Number243-7862
  • UPC781462210007
  • Product CategoryMoving Yoke & Scanner Intelligent Lighting
  • Weight27.0000 lbs.
View similar products to the CHAUVET DJ Intimidator Spot Duo DMX LED Double Moving Head Fixture
in the Moving Yoke & Scanner Intelligent Lighting product category.
Customer projects that include: CHAUVET DJ Intimidator Spot Duo DMX LED Double Moving Head Fixture
