CHAUVET DJ Intimidator Barrel LED 300 DMX LED Barrel Effect Light
Brand:|Model: INTIMBARREL300|Part # 243-7684
The Intimidator™ Barrel LED 300 by Chauvet includes seven interchangeable, rotating gobos and eight separate, saturated colors for increased design flexibility and effects.
  • Bright and compact LED barrel with tons of features to enhance any show
  • Interchangeable, rotating gobos plus separate, saturated colors allow extra flexibility and effects
  • Built-in movement macros and move-in-black features minimize programming time
  • Motorized focus allows the gobos to be crisp when projected at almost any distance
  • Electronic dimming and strobe features deliver silent operation with no moving parts
  • Crisp, 3-sided prism duplicates the beam for great effects and to cover a larger area
  • Individual reset of pan/tilt, color, gobo, prism and focus allows the show to continue no matter what happens
This bright and compact LED powered barrel scanner comes with tons of features to enhance any show. Motorized focus allows for crisp gobos when projected from almost any distance. High-frequency LED dimming allows for flicker-free video operation. Sound-activated programs dance to the beat of the music. Easy-access to built-in automated programs generate a synchronized show in master/slave mode. Power linking saves time running cables and extension cords (US version only).
Specifications: • DMX channels: 8 or 11 • DMX connectors: 3-pin • Pan and tilt: 180° / 360° • Colors: 8 + white, split colors, continuous scroll at variable speeds • Gobos: 7 + open, rotating, slot-n-lock, continuous scroll at variable speeds • Gobo size: 23.8 mm outside, 20.9 mm image, 2 mm max thickness • Light source: one white 60W (15 A) LED rated for 50,000 hours • Strobe rate: 0 - 20 Hz • Illuminance: 1,736 lux @ 2 m • Power linking: 3 units @ 120V / 7 units @ 230V • Input voltage: Switchable 120/230 VAC 50/60 Hz • Power and current: 240 watts, 2A @ 120V 60 Hz • Power and current: 240 watts, 1A @ 230V 50 Hz • Dimensions: 20.5" x 10" x 6.7" (521 x 255 x 171 mm) • Weight: 14.2 lbs. (6.4 kg) • Approvals: CE, MET.
  • DMX-ControllableYes
  • BrandCHAUVET DJ
  • ModelINTIMBARREL300
  • Part Number243-7684
  • UPC781462208257
  • Product CategoryClub & DJ Effects Lighting
  • Weight14.2 lbs.
View similar products to the CHAUVET DJ Intimidator Barrel LED 300 DMX LED Barrel Effect Light
in the Club & DJ Effects Lighting product category.
