Chauvet DJ Impulse 648 Super Bright LED Strobe Panel
Brand:|Model: IMPULSE648|Part # 243-7718
Chauvet's Impulse 648 is an LED panel with 648 bright white LEDs for a great blast of intense light!
  • Professional and rugged LED strobe light designed for the mobile entertainer, permanent installation or lighting professional
  • Road-ready SMD LEDs offer a great blend of intensity and toughness
  • Built-in 3-pin and 5-pin DMX connectors allow greater flexibility for different applications
  • Radiant cooling design allows for use in the most sound-sensitive environments
  • Locking IEC power input ensures the power cord never comes out
  • User-adjustable intensity and strobe rates in stand-alone eliminate the need for an external controller
Impulse™ 648 harnesses the power of 648 white SMD LEDs to deliver an astonishingly bright strobe light. A lightweight, sleek housing holds the LED array while 3 and 5-pin DMX connections make set up and installation a breeze. Silent, fan-free operation allows for use in noise-sensitive environments. Innovative all-on feature allows the Impulse™ 648 to be used as a flood light.
Specifications: • DMX channels: 2 • DMX connectors: 3-pin & 5-pin • Light source: 648 white (60 mA) SMD LEDs rated for 50,000 hours • Color temperature: 6500 - 7000 K • Strobe rate: 0 - 30 Hz • Beam angle: 66° • Field angle: 105° • Viewing angle: 120° • Illuminance: 909 lux @ 2m • Power linking: 5 units @ 120V / 10 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 237W, 1.9A @ 120V 60 Hz • Power and current: 235W, 1A @ 230V 50 Hz • Size: 16.7" x 8.8" x 6.5" (424 x 224 x 164 mm) • Weight: 10.6 lbs. (4.8 kg) • Approvals: CE.
  • Light TypePanel Bank
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelIMPULSE648
  • Part Number243-7718
  • UPC781462208097
  • Product CategoryWash Lights / Stage Lighting
  • Weight10.6 lbs.
View similar products to the Chauvet DJ Impulse 648 Super Bright LED Strobe Panel
in the Wash Lights / Stage Lighting product category.
