243-7912_ALT_0
243-7912_ALT_1
243-7912_ALT_2
243-7912_ALT_3
243-7912_ALT_4
243-7912_ALT_5
243-7912_ALT_6
243-7912_ALT_7
Chauvet DJ Freedom Strip Mini RGBA Wireless Rechargeable DMX LED Wash Light
Brand:|Model: FREEDOMSTRIPMINIRGBA|Part # 243-7912
The Freedom™ Mini RGBA is a 100% wireless, battery-operated, quad-color linear LED fixture with built-in D-Fi™ 2.4GHz wireless control. With 200 powerful RGBA LEDs, you can now put gorgeous, rich colors virtually anywhere you want, with no cables of any kind needed.
  • Full-featured LED linear wash with rechargeable battery power
  • Runs up to 20 hours on a single charge
  • Fully wireless DMX on-board, or use included IR remote for easy non-DMX operation
  • Built-in, sound-activated, automated and master/slave modes for simple setup
Chauvet's Freedom™ Strip Mini RGBA pairs the familiar Freedom™ Strip Mini form factor with high-power quad-color LEDs. Two hundred (200) 5-watt RGBA LEDs produce vivid, saturated colors, while the use of 10mm LEDs provides a tighter beam. A completely wireless DMX control option is available and made easy using built-in battery power and an integrated D-Fi™ 2.4 GHz DMX system. For even easier operation when DMX isn't needed, point-and-shoot operation is available using the included IRC (infrared remote control).
Easily create coordinated light shows by linking COLORstrip™, COLORstrip™ Mini, and other Freedom™ Series fixtures in master/slave mode using the on-board D-Fi™ 2.4 GHz technology.
Specifications: • DMX channels: 4 or 5 • DMX connectors: 3-pin • Light source: 200 (50 red, 50 green, 50 blue, 50 amber) 0.25W (20mA) LEDs • Typical run time (full on): up to 8 hours • Typical run time (single color): up to 20 hours • Recharge time: 6 hours • Beam angle: 13° • Field angle: 24° • Wireless operating frequency: 2.433 - 2.481GHz • Illuminance: 1,370lux @ 2m • Power linking (wired operation): 16 units @ 120V; 25 units @ 230V • Input voltage (wired operation): auto-ranging 100~240 VAC 50/60 Hz • Power and current (wired operation): 71W, 0.6A @ 120V 60 Hz • Power and current (wired operation): 94W, 0.4A @ 230V 50 Hz • Weight: 7.6 lbs. (3.4 kg) • Size: 20" x 3" x 8.3" (510 x 78 x 210 mm).
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelFREEDOMSTRIPMINIRGBA
  • Part Number243-7912
  • UPC781462209575
  • Product CategoryWash Lights / Stage Lighting
  • Weight8 lbs.
View similar products to the Chauvet DJ Freedom Strip Mini RGBA Wireless Rechargeable DMX LED Wash Light
in the Wash Lights / Stage Lighting product category.
