Chauvet DJ EZrail RGBA Rechargeable DMX LED Linear Wash Light
Brand:|Model: EZRAILRGBA|Part # 243-7900
The EZrail™ RGBA is a battery-powered, cable-free linear LED fixture. It goes anywhere light is needed, with a rechargeable lithium battery that lasts up to 20 hours on a single charge.
  • Full-featured LED linear wash with rechargeable battery power
  • Runs up to 20 hours on a single charge
  • Fully DMX compatible, but also includes IR remote for non-DMX operation
  • Built-in, sound-activated, automated and master/slave modes for simple setup
Chauvet's innovative EZrail™ RGBA is a battery-powered linear wash light designed to free the mobile entertainer from the hassle of running cables, and to drastically improve setup and tear down times. The rechargeable lithium-ion battery lasts up to 20 hours on a single charge to deliver stunning colors for the duration of your event. Easily keep tabs on the remaining charge using the visible battery-life indicator.
The EZrail™ is ideal for uplighting walls, tables, structural features, or adding light and color to any areas you wish in larger venues, without having to run cables here and there and everywhere. The on-board control panel and included IR remote control make setup and operation a breeze, or you can add a wireless D-Fi™ receiver (sold separately) to create a completely wireless DMX solution for more advanced applications. The unique bracket system allows the fixture to be mounted to truss in the traditional manner, or to be set on the floor (or virtually any flat surface) with confidence, and the color can be set to a single color, or different colors in up to four sections.
Specifications: • DMX channels: 2, 4, 5, 8, 10 or 18 • DMX connectors: 3-pin • Light source: 160 (40 red, 40 green, 40 blue, 40 amber) 0.25W (20mA) LEDs rated for 100,000 hours • Strobe rate: 0 - 16 Hz • Beam angle: 15° • Field angle: 30° • Illuminance: 805 lux @ 2m • Power linking: 32 units @ 120V; 64 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 31W, 0.2A @ 120V 60 Hz • Power and current: 33W, 0.1A @ 230V 50 Hz • Weight: 5.6 lbs. (2.6 kg) • Size: 19.9" x 2.9" x 6.1" (505 x 73 x 155 mm).
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelEZRAILRGBA
  • Part Number243-7900
  • UPC781462210397
  • Product CategoryWash Lights / Stage Lighting
  • Weight7.2 lbs.
View similar products to the Chauvet DJ EZrail RGBA Rechargeable DMX LED Linear Wash Light
in the Wash Lights / Stage Lighting product category.
