Chauvet DJ D-Fi Tx 2.4 Wireless 2.4 Ghz Transmitter
Brand:|Model: D-Fi Tx 2.4|Part # 243-7826
The D-Fi Series consists of compact, easy to use wireless DMX transmitters and receivers which alleviate the cable nightmares generally associated with setting up and tearing down your light show.
  • Up to 656 ft of cable-free DMX communication (line of sight)
  • Compatible with all Chauvet D-Fi 2.4 products
  • Wirelessly sync multiple receivers to a single Chauvet D-Fi 2.4 transmitter
  • Quick and easy single button sync process
  • Adjustable antenna complete with a safety transport clip
  • Multiple mounting options include a M12 threaded hole for clamp, and teardrop holes for wall mounting
Frequently Bought Together
The D-Fi™ Tx 2.4 is the latest addition to the D-Fi™ family of easy to use, wireless DMX units. The super-compact Tx model acts solely as a transmitter for any product that receives the D-Fi™ 2.4GHz signal including: D-Fi™ Rx 2.4, D-Fi™ 2.4GHz and Freedom™ Series. For more stable communication between units, this version operates on a 2.4 GHz frequency range and includes an auto function which automatically finds the best frequency available, and effortlessly syncs the units.
Specifications: DMX connectors: 3-pin • Max unobstructed (line-of-sight) distance: 656 ft. (200m) • Input voltage: 9 VDC, 500 mA (external power supply: 100~240VAC) • Operating frequency: 2.433 - 2.481 GHz • RF output: 18.5 dBm • Refresh rate: 15 Hz • Antenna connection: RP-SMA • Weight: 0.4 lbs. (0.18 kg) • Size: 3.8" x 2.6" x 1.5" (97 x 66 x 38 mm).
  • BrandChauvet DJ
  • ModelD-Fi Tx 2.4
  • Part Number243-7826
  • UPC781462208646
  • Product CategoryDMX Cables, Splitters & Controller Accessories
  • Weight0.4 lbs.
View similar products to the Chauvet DJ D-Fi Tx 2.4 Wireless 2.4 Ghz Transmitter
in the DMX Cables, Splitters & Controller Accessories product category.
