Chauvet DJ D-Fi 2.4 Tx/Rx Duo Wireless DMX Combo
Brand:|Model: D-Fi 2.4 Tx/Rx|Part # 243-7830
The D-Fi Series consists of compact, easy to use wireless DMX transmitters and receivers which alleviate the cable nightmares generally associated with setting up and tearing down your light show.
  • Includes one D-Fi™ 2.4 Tx and one D-Fi™ 2.4 Rx in convenient carrying case
  • Up to 656 ft of cable-free DMX communication (line of sight)
  • Compatible with all Chauvet D-Fi 2.4 products
  • Wirelessly sync multiple receivers to a single Chauvet D-Fi 2.4 transmitter
  • Quick and easy single button sync process
  • Adjustable antenna complete with a safety transport clip
  • Multiple mounting options include a M12 threaded hole for clamp, and teardrop holes for wall mounting
Frequently Bought Together
The D-Fi™ 2.4 Tx/Rx Duo is a convienent pack of one D-Fi™ Tx 2.4 and one D-Fi™ Rx 2.4. The super-compact Rx model acts solely as a receiver and the Tx model acts solely as a transmitter for wireless DMX. They are also compatible with any product that runs on the D-Fi™ 2.4 GHz signal including: D-Fi™ 2.4GHz and Freedom™ Series. For more stable communication between units, this version operates on a 2.4 GHz frequency range and includes an auto function which automatically finds the best frequency available and effortlessly syncs the units.
Specifications: DMX connectors: 3-pin • Max unobstructed (line-of-sight) distance: 656 ft. (200m) • Input voltage: 9 VDC, 500 mA (external power supply: 100~240 VAC) • Operating frequency: 2.433 - 2.481 GHz • RF output: 18.5 dBm • Refresh rate: 15 Hz • Antenna connection: RP-SMA • Weight (each unit): 0.4 lbs. (0.18 kg) • Size (each unit): 3.8" x 2.6" x 1.5" (97 x 66 x 38 mm).
  • BrandChauvet DJ
  • ModelD-Fi 2.4 Tx/Rx
  • Part Number243-7830
  • UPC781462209063
  • Product CategoryDMX Cables, Splitters & Controller Accessories
  • Weight2.3 lbs.
View similar products to the Chauvet DJ D-Fi 2.4 Tx/Rx Duo Wireless DMX Combo
in the DMX Cables, Splitters & Controller Accessories product category.
