CHAUVET DJ COLORstrip DMX RGB LED Linear Wash Light
Brand:|Model: COLORstrip|Part # 243-7106
CHAUVET's COLORstrip™ is an LED-fitted strip fixture. The unit can be controlled via four DMX channels, multiple modes accessible via the control panel–pre-programmed flash, color chase, sequential color chase, color mixing and color fade patterns–or an optional LED-FS1 controller.
List Price$219.99
You Save27%
$159.99
Part # 243-7106
  • 4-channel DMX-512 LED linear wash light
  • Blackout/static/dimmer/strobe
  • Static colors and RGB color mixing with or without DMX controller
  • Built-in automated programs via master/slave or DMX
  • Built-in sound activated programs via master/slave or DMX
  • Compatible with CHAUVET® Satellite™ system
  • Additional power output: max 15 units @ 120V (see manual for details)
CHAUVET's COLORstrip™ is an LED-fitted strip fixture. The unit can be controlled via four DMX channels, multiple modes accessible via the control panel, or an optional LED-FS1 controller. The COLORstrip™ features built-in programs with automatic and sound-active triggers, and allows access to popular preset RGB mixed colors: yellow, purple, cyan and white. The fixture is equipped with pre-programmed flash, color chase, sequential color chase, color mixing and color fade patterns. Jacking the COLORstrip™ into a DMX controller gives the programmer access to all pre-programmed features as well as to speed adjustments for fade and flash. At 38" long, 2.5" wide, and weighing less than 5 lbs., it is ideal for creating "runway" effects without cluttering up the catwalk.
Specifications: • Beam angle: 53° x 27° • Field angle: 68° x 46° • Lux: 1,127 @ 1m • Light source: 384 (128 red, 128 green, 128 blue) LEDs • Power and current: 120V, 60 Hz: 28W, 0.4A operating, 0.4A inrush • AC power: auto-switching 100~240 VAC, 50/60 Hz • Weight: 4.5 lbs.  (2 kg) • Size: 38" x 2.5" x 6" (965 x 64 x 152 mm).
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandCHAUVET DJ
  • ModelCOLORstrip
  • Part Number243-7106
  • UPC781462000431
  • Product CategoryWash Lights / Stage Lighting
    (1 Reviews)
  • Weight7.05 lbs.
View similar products to the CHAUVET DJ COLORstrip DMX RGB LED Linear Wash Light
in the Wash Lights / Stage Lighting product category.
CHAUVET DJ COLORstrip DMX RGB LED Linear Wash Light is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great wash lights and moreI started with two of these and now I have Five. these led wash bars are more than color washes. I use them for many purposes. Wash lights, uplighting, downlighting, behind a band/DJ, stage wash, runway for fashion shows, inside tents. I plan on buying more for larger events. These wash lights give you more bang for the buck. As long as you take care when transporting, they should last for a long time, no heat, less power to operate,simple to set up and take down, less wiring as you can link both the power and signal from one to the rest. Great for clubs.
Date published: 2012-11-01
  • 2016-02-09T06:37CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_243-7106, PRD, sort_mostRecent
