Chauvet DJ COLORrail IRC IP Multicolored Strip Light Outdoor Rated
Brand:|Model: COLORRAILIRCIP|Part # 243-7734
Chauvet's COLORrail™ IRC IP is an RGB LED linear wash/effect that uses 320 tightly packed 10 mm LEDs.
  • Multicolored strip light for use in indoor or outdoor mobile entertainment applications
  • Perfect for lighting any outdoor event
  • No need to rush through setup or teardown in the rain because the fixture is weatherproof
  • Use behind wet bars or at outdoor parties without fear of damaging the fixture
  • Robust housing repels water, snow, dirt, sand and salt for all-weather applications
  • Use with the IRC remote control (sold separately) for non-DMX wireless operation
  • Create dazzling effects by controlling up to 8 LED sections
COLORrail™ IRC IP is an RGB LED linear wash/effect light rated IP65 for outdoor mobile applications. Powered by 320 tightly packed and evenly distributed 10 mm RGB LEDs for a multitude of effects and applications. The fixture is DMX controllable in up to 8 sections, or choose from a multitude of captivating automatic programs including chase and runway effects. Optional control is also available wirelessly from the IRC remote control with no DMX needed. Power linking saves time running cables and extension cords.
Specifications: • DMX channels: 2, 3, 4, 7, 14, or 26 • DMX connectors: 3-pin • Light source: 320 (128 red, 96 green, 96 blue) LEDs • Beam angle: 14° (per section) • Field angle: 22° (per section) • Illuminance: 418 lux @ 2m • IP rating: IP65 • Startup temperature: -4° to 113°F (-20°C to 45°C) • Operating temperature: -22° to 113°F (-30°C to 45°C) • Power linking: 15 units @ 120V / 28 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 60W, 0.5A @ 120V 60 Hz • Power and current: 65W, 0.3A @ 230V 50 Hz • Dimensions: 4.7" x 43.6" x 5.1" (120 x 1109 x 130 mm) • Weight: 12.4 lbs. (5.6 kg) • Approvals: CE.
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelCOLORRAILIRCIP
  • Part Number243-7734
  • UPC781462206482
  • Product CategoryWash Lights / Stage Lighting
  • Weight12.4 lbs.
View similar products to the Chauvet DJ COLORrail IRC IP Multicolored Strip Light Outdoor Rated
in the Wash Lights / Stage Lighting product category.
