Chauvet DJ COLORband PiX Mini LED DMX Strip Light
Brand:|Model: COLORBANDPIXMINI|Part # 243-7694
Chauvet COLORband PiX Mini has six individually controllable tri-colored LEDs that project custom animations and video effects when multiple units are used together.
  • Half-sized LED strip light for use as a pixel mapping effect, blinder or wall-washer
  • Individual LED control provides the ability to create amazing animations and video effects
  • Many pre-built automated programs accessible with or without DMX
  • Works with ShowXpress™ Pixels to generate complex looks with ease
  • Onboard 3-pin and 5-pin DMX connectors offer great flexibility
  • High-frequency LED dimming allows for flicker-free video operation
  • Includes multiple DMX personalities to fit a wide variety of programming styles
Great for use as a powerful wash with the additional eye candy of pixel mapping effects, COLORband™ PiX Mini is a must-have fixture for mobile DJs or club installers looking for high-impact visuals on a budget. This powerful, compact version of COLORband PiX™ also features full pixel mapping capability. Six individually controllable tri-colored LEDs project custom animations and video effects when multiple units are used together. COLORband™ PiX Mini includes multiple DMX personalities and pre-built programs for design flexibility at any event while on-board 3- and 5-pin DMX connectors increase control options.
High-powered, tri-color LEDs nearly eliminate multi-colored shadows. The COLORband PiX Mini is linkable with other COLORband™ PiX Mini, COLORband™ PiX and COLORband™ Tri fixtures for a coordinated light show. Great for quiet installations thanks to the 100% silent operation and no moving parts. Power linking saves time running cables and extension cords.
Specifications: • DMX channels: 3, 4, 6, 7, 9, or 18 • DMX connectors: 3-pin and 5-pin • Light source: Six 3W (350 mA x3) tri-color LEDs rated for 50,000 hours • Strobe rate: 0 - 30 Hz • Beam angle: 20° • Field angle: 34° • Illuminance: 1,300 lux @ 2m • Power linking: 20 units @ 120V / 35 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 47 watt, 0.4A @ 120V 60 Hz • Power and current: 51 watt, 0.2A @ 230V 50 Hz • Weight: 4.9 lbs. (2.2 kg) • Dimensions: 21.8" x 2.5" x 6.1" (554 x 64 x 154 mm) • Approvals: CE, MET.
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelCOLORBANDPIXMINI
  • Part Number243-7694
  • UPC781462208226
  • Product CategoryWash Lights / Stage Lighting
  • Weight4.9 lbs.
View similar products to the Chauvet DJ COLORband PiX Mini LED DMX Strip Light
in the Wash Lights / Stage Lighting product category.
