Chauvet DJ COLORband PiX IP DMX LED Strip Light
Brand:|Model: COLORband PIX IP|Part # 243-7804
Worry-free, outdoor rated LED strip light for use as a pixel mapping effect, blinder or wall-washer.
Ships in 7-10 Business Days
List Price$479.99
You Save25%
Part # 243-7804
  • Individual LED control provides the ability to create amazing animations and video effects
  • Robust housing repels water, snow, dirt, sand and salt for all-weather applications
  • Password-protected, touch-sensitive digital display ensures no one changes the show
  • Power and data linking outputs simplifies installations by reducing extra extension cables
  • Integrated Gore™ valve prevents internal humidity build-up and allows the fixture to breathe
  • Linkable with other COLORband™ PiX, COLORband™ PiX Mini, and COLORband™ Tri fixtures for a coordinated light show
Perfect for both indoor and outdoor events, as a member of the COLORIST® range of fixtures, this IP65-rated fixture means you no longer have to worry about rain or a spilled drink ruining your fixtures. Great for use as a powerful wash with the additional eye candy of pixel mapping effects, COLORband™ PiX IP is a must-have fixture for mobile DJs, club installers, or anyone looking for high-impact visuals on a budget. Use multiple units together to easily generate video effects and animations. Individual control over 12 flicker-free, tri-colored LEDs allows for custom looks at any event while impressive, built-in programs are accessible with or without DMX. The COLORband™ PiX IP is compatible with ShowXpress™ Pixels to generate complex looks with ease, and is perfectly suitable for use on camera due to the flicker-free operation
Specifications:   DMX channels: 3, 4, 6, 7, 9, 12, 18 or 36 • DMX connectors: 3-pin • Light source: 12 x 3W (350 mA x3) tri-color LEDs rated for 50,000 hrs • Strobe rate: 0 - 30 Hz • Beam angle: 20° • Field angle: 34° • Illuminance: 1,952 lux @ 2m • IP rating: IP65 • Power linking: 9 units @ 120VAC / 17 units @ 230VAC • Input voltage: auto-ranging 100~240 VAC 50/60 Hz • Power and current: 98W, 0.7A @ 120VAC; 103W, 0.4A @ 230VAC • Weight: 13.5 lbs (6.1 kg) • Size: 39" x 3.9" x 6.8" (993 x 100 x 173 mm).
  • Light TypeLinear Strip
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelCOLORband PIX IP
  • Part Number243-7804
  • UPC781462208912
  • Product CategoryWash Lights / Stage Lighting
  • Weight8.9 lbs.
