Chauvet DJ BEAMShot DMX LED Aerial Effects Light w/4 Color Gels
Brand:|Model: BEAMSHOT|Part # 243-7886
The BEAMshot super-compact aerial effect light outshines the competition with a narrow, razor-sharp beam of bright white light. Use the included gels to add a splash of vibrant color to the beam.
Part # 243-7886
  • Super-sharp, bright pinspot light fixture with four different colored gels
  • Build impressive matrices and runway effects by linking multiple units
  • Built-in, sound-activated, automated, and master/slave modes for simple setup and operation
  • Full DMX control, including full pixel control via free software for more advanced applications
The BEAMshot™ from Chauvet is a unique, LED-powered effect light that shoots an intense, ultra-narrow beam of light wherever you need it. Easily transform piercing beams into a brilliant array by linking multiple units. Maximum effect is achieved by incorporating fog or haze, so the beams are more apparent. Install your choice of the included gels (yellow, green, blue, or purple) quickly and easily, and enjoy a snappy splash of color. Link multiple units, and take command with full pixel control using ShowXpress™ Pixels (free software available, hardware required and sold separately), which facilitates the creation of eye-catching sweeps and animations in DMX mode.
Also great for retail spaces, art installations and displays, or anywhere you may wish to draw attention to a particular area or feature with a small, concentrated beam of light, minus the heat generally associated with such powerful spotlights.
Specifications: • DMX channels: 2 or 4 • DMX connectors: 3-pin • Light source: one white 6W (1.5A) LED rated for 50,000 hours • Strobe rate: 0 - 20Hz • Beam angle: 3° • Illuminance: 16,350 lux @ 2m • Power linking: 62 units @ 120V; 100 units @ 230V • Input voltage: auto-ranging 100~240 VAC 50/60Hz • Power and current: 15W, 0.1A @ 120V 60Hz • Power and current: 19W, 0.1A @ 230V 50Hz • Weight: 1.4 lbs. (0.7 kg) • Size: 8.3" x 5.7" x 4.1" (210 x 145 x 105 mm).
  • BrandChauvet DJ
  • ModelBEAMSHOT
  • Part Number243-7886
  • UPC781462210168
  • Product CategoryPin Spots & Mirror Balls
  • Weight2.6 lbs.
View similar products to the Chauvet DJ BEAMShot DMX LED Aerial Effects Light w/4 Color Gels
in the Pin Spots & Mirror Balls product category.
