243-7872_ALT_0
243-7872_ALT_1
243-7872_ALT_2
243-7872_ALT_3
243-7872_ALT_4
243-7872_ALT_5
243-7872_ALT_6
243-7872_ALT_7
Chauvet DJ Abyss LED 3.0 DMX 5-Color Rippling Water Effects Light
Brand:|Model: ABYSSLED3.0|Part # 243-7872
Give your audience the illusion of dancing on water with the Abyss™ LED 3.0 from Chauvet. The applications for this innovative piece are limited only by your imagination!
  • Two glass effect wheels and one dichroic color wheel
  • Individual control of the wheels gives you great flexibility and variety
  • Stunning effects, with or without fog
  • Easy setup and operation, with or without DMX control
Chauvet's Abyss™ LED 3.0 is a very eye-catching, multi-colored, simulated water effect light with countless uses. A powerful 15-watt white LED shines through any environment with or without fog, while two glass effect wheels and one dichroic color wheel can be controlled individually for optimal projections and effects.
Create your own breathtaking customized rippling water illusions; use cooler shades of blue for a soothing, realistic effect, or warmer tones like red and orange to crank up the heat to simulate a fiery phenomenon. With the Abyss LED 3.0, it's all up to you!
Specifications: • DMX channels: 2 • DMX connectors: 3-pin • Light source: one 15W (2.8A) LED rated for 50,000 hours • Beam angle: 30° • Input voltage: auto-ranging 100~240 VAC 50/60Hz • Power and current: 52W, 0.4A @ 120V 60Hz • Power and current: 57W, 0.2A @ 230V 50Hz • Power linking: 24 units @ 120V; 37 units @ 230V • Weight: 10.1 lbs. (4.6 kg) • Size: 35.5" x 2.2" x 6.5" (902 x 56 x 165 mm).
  • DMX-ControllableYes
  • BrandChauvet DJ
  • ModelABYSSLED3.0
  • Part Number243-7872
  • UPC781462207533
  • Product CategoryClub & DJ Effects Lighting
    (1 Reviews)
  • Weight7.35 lbs.
View similar products to the Chauvet DJ Abyss LED 3.0 DMX 5-Color Rippling Water Effects Light
in the Club & DJ Effects Lighting product category.
