243-7548_ALT_0
243-7548_ALT_1
243-7548_ALT_2
243-7548_ALT_3
243-7548_ALT_4
243-7548_ALT_5
243-7548_ALT_6
Chauvet DJ 6SPOT LED Powered Color Changer System
Brand:|Model: 6SPOT|Part # 243-7548
Chauvet's 6SPOT contains 6 independently positioned heads with high powered tri-colored LEDs that create 7 colors. It mounts on to almost any universal tripod stand and comes with its own travel bag.
List Price$349.99
You Save29%
$249.99
Part # 243-7548
  • Complete, portable LED spot lighting solution with high-intensity, tri-color LEDs
  • Six, independently-positional heads allow total room or stage coverage
  • Low-profile spots are 3.6in deep and can fit almost anywhere
  • Set-up and teardown in minutes with the included carry bag
  • High-powered, tri-colored LEDs mix to instantly create 7 popular colors
  • Safely mount to truss using the built-in bolts for increased flexibility and mounting options
  • Works in master/slave with the Sweeper™ LED for large, coordinated light shows
With the 6SPOT color-changing system by Chauvet you can be sure to have total room coverage with 6 independently positioned heads. The high-powered LEDs within each head mix together to create 7 colors. Each spot is only 3.6" deep so the entire system can fit almost anywhere. Mount to a truss using the built-in bolts for increased flexibility and mounting options or slide the system onto almost any universal tripod stand. Same time running cables and extension cords by power linking up to 20 units together. Comes with its own travel bag.
Specifications: • DMX channels: 8 • Light source: Six 3 watt (375mA x3) tri-color LEDs • Strobe rate: 0-30 Hz • Beam angle: 11° (per light) • Lux: 814 @ 1m (per light) • Power and current: 120V, 60 Hz: 52 watts, 0.4A operating • Power and current: 230V, 50 Hz: 57 watts, 0.2A operating • AC power: auto-switching 100~240 VAC, 50/60 Hz • Power linking: max 20 units @ 120V (see manual for details) • Weight: 10.1 lbs. (4.6 kg) • Dimensions: 35.5" x 2.2" x 6.5" (902 x 56 x 165 mm).
  • Light TypeMicro/Compact
  • DMX-ControllableYes
  • BrandChauvet DJ
  • Model6SPOT
  • Part Number243-7548
  • UPC781462206420
  • Product CategoryWash Lights / Stage Lighting
    (1 Reviews)
  • Weight13.3 lbs.
View similar products to the Chauvet DJ 6SPOT LED Powered Color Changer System
in the Wash Lights / Stage Lighting product category.
Videos
