243-7546_ALT_0
243-7546_ALT_1
243-7546_ALT_2
243-7546_ALT_3
243-7546_ALT_4
Chauvet DJ 4PLAY CL LED Moonflower Beam Effect System Clear
Brand:|Model: 4PLAY CL|Part # 243-7546
The 4PLAY by Chauvet has red, green, blue, and white beams that create moonflower lighting effect. This two-in-one effect light is a complete lighting system package equipped with its own carrying case.
  • Mobile, two-in-one effect light that projects tons of beams with 4 internally-lit clear heads
  • The light becomes part of the show with the light-weight, clear casing
  • Razor-sharp rotating beams penetrate through the air with no moving parts
  • Mounts safely to the 4BAR™ tripod or most tripods or speaker stands
  • Each head can be positioned independently to achieve maximum room coverage
  • Awesome sound-activated programs dance to the beat of the music
  • Easy-access to built-in automated programs generate a synchronized show in master/slave mode
This two-in-one effect light is a complete lighting system package equipped with its own carrying case. The 4 internally-lit clear heads cast beams of red, green, blue, and white light. Each head can be individually controlled for complete customization. Use the included bolts to mount the bar to a truss to save floor space. The mounting bar also features a pass-through to allow the unit to be mounted quickly to a tripod or speaker stand. Save time running cables and extension cords by linking up to 30 units together.
Specifications: • DMX channels: 6 • Light source: 228 (48 red, 72 green, 72 blue, 36 white) LEDs (57 per light) • Coverage angle: 25° (per light) • Power and current: 120V, 60 Hz: 12 watts, 0.2A operating, 0.2A inrush; 230V, 50 Hz: 11 watts, 0.2A operating, 0.2A inrush • AC power: auto-switching 100~240 VAC, 50/60 Hz • Power linking: max 30 units @ 120V (see manual for details) • Weight: 12.7 lbs. (5.7 kg) • Dimensions: 33" x 3.5" x 12.5" (838 x 89 x 318 mm).
  • DMX-ControllableYes
  • BrandChauvet DJ
  • Model4PLAY CL
  • Part Number243-7546
  • UPC781462206376
  • Product CategoryClub & DJ Effects Lighting
    (1 Reviews)
  • Weight16 lbs.
View similar products to the Chauvet DJ 4PLAY CL LED Moonflower Beam Effect System Clear
in the Club & DJ Effects Lighting product category.
Videos
