Clearance Item
243-7586_ALT_0
243-7586_ALT_1
243-7586_ALT_2
243-7586_ALT_3
243-7586_ALT_4
243-7586_ALT_5
243-7586_ALT_6
243-7586_ALT_7
Chauvet Cosmos LED Continuously Rotating Lighting Effect
Brand:|
Chauvet's Cosmos LED is a rotating ball effect light with four 3W tri-colored LEDs. The plug-and-play Cosmos can be taken right out of the box and with no duty cycle, it can run all night long!
  • Easy-to-use dual rotating ball effect
  • Effects rotates 360-degrees continuously
  • Manually adjustable rotation speed
  • Built-in sound-activated programs for LEDs
  • High-power, 3 watts (1,050mA) tri-color LEDs
  • Power linking: max 24 units @ 120V (see manual for details)
243-7586
Weight: 13.55 lbs.
The plug-and-play Cosmos can be taken right out of the box and with no duty cycle, it can run all night long. Features 3 watt tri-colored LEDs with adjustable speeds for continuous 360° rotation. Save time running cables and extension cords by linking up to 24 units together.
Specifications: • Coverage angle: 360° • Light source: Four 3W (350mA x3) tri-color LEDs 50,000 hrs • Power and current: 120V, 60 Hz: 11 watts, 0.3A operating, 0.2A inrush • AC power: Auto-switching 100~240V, 50/60 Hz • Weight: 8.9 lbs. (4 kg) • Dimensions: 8" x 21.5" x 11.5" (203 x 546 x 292 mm).
  • DMX-ControllableNo
  • BrandChauvet
  • Part Number243-7586
  • UPC781462205768
  • Product CategoryClub & DJ Effects Lighting
  • Weight13.55 lbs.
View similar products to the Chauvet Cosmos LED Continuously Rotating Lighting Effect
in the Club & DJ Effects Lighting product category.
Customer projects that include: Chauvet Cosmos LED Continuously Rotating Lighting Effect
