099-102_ALT_0
Chassis Mount Two Conductor Screw Terminal Block
Brand:|Part # 099-102
This is a heavy-duty two terminal screw block for chassis mounting. Features superior construction: Break-resistant, high-impact thermoplastic, mo pin twist for fewer broken solder joints, supports up to 12 AWG conductors.
Comparable Items In Stock:
Part # 099-102
  • Spacing; 3/8" center to center
  • Wire gauge range: 22AWG - 12AWG
  • Voltage rating: 300 volts
  • Current rating: 20 amps
  • UL recognized, CSA certified
Frequently Bought Together
This is a heavy-duty two terminal screw block for chassis mounting. Features superior construction: Break-resistant, high-impact thermoplastic, mo pin twist for fewer broken solder joints, supports up to 12 AWG conductors. Specifications: Spacing: 3/8" center to center, Wire gauge range: 22AWG to 12AWG, Voltage rating: 300 volts, Current rating: 20 amps, Terminals: tin-plated brass. Connection via 0.187" and 0.250" disconnects. Easily mountable with two screw holes. Limited availability factory buyout.
  • BrandFactory Buyouts
  • Part Number099-102
  • UPC844632081620
  • Product CategoryPower Distribution Hardware
    (1 Reviews)
  • Weight0.02 lbs.
View similar products to the Chassis Mount Two Conductor Screw Terminal Block
in the Power Distribution Hardware product category.
