Channel Vision WA-361 Wireless Audio Receiver
Brand:|Model: WA-361|Part # 183-253
Create a distributed audio system without having to run wire! The Channel Vision WA-361 receives audio signal wirelessly from the WA-321 and passes it along to a local amplifier via stereo line-level RCA audio outputs.
  • Create a wireless distributed audio system
  • Operates on one of 8 channels for discrete signal transmission
  • Designed to work with the Channel Vision WA-321 transmitter (sold separately)
  • Sends audio signal to a local amplifier—great for remote audio zones!
Channel Vision's WA-361 single source to unlimited destination wireless audio receiver combines with the WA-321 wireless audio transmitter (sold separately) to create a distributed audio system without running wires from one room to another.
The WA-361 outputs line-level RCA audio to a local amplifier, making it easy to distribute signals to remote located speakers. Channel Visions' WA-361 wireless receiver and WA-321 wireless transmitter link together on a one-to-one basis and can operate over eight different transmission channels—perfect for multi-source and multi-room audio, subwoofers, rear home theater speakers, or an entire 5.1 home theater applications. Single gang size, mounting bracket sold separately. Power supply included.
• 300 ft. wireless range
• Input voltage: 5 VDC, 250 mA
• THD+N: 0.7%
• Signal-to-noise ratio: 80 dB
• Audio latency: 3.8 ms
• Operating frequency: 2400 MHz
• Data rate: 1.152 Mbps
• Audio sampling rate: 48 kHz
• Receiver sensitivity: -85 dBm
• Image rejection: 47 dBc
• Audio output level: 2.6V
• Frequency response: 20-20,000 Hz (±3 dB)
  • BrandChannel Vision
  • ModelWA-361
  • Part Number183-253
  • UPC690240025224
  • Product CategoryAudio Distribution Systems
  • Weight1 lbs.
