Channel Vision IR-1203 Amplified IR Repeater Hub
Brand:|Model: IR-1203|Part # 183-195
Channel Vision's IR-1203 amplified IR hub is designed to integrate a distributed IR control system into homes, offices, or retail showrooms quickly.
List Price$46.20
You Save44%
$25.67
Part # 183-195
  • Quickly creates a distributed IR control system
  • Screw down IR target terminals
  • Four emitter outputs
  • Power supply included
  • Status and power LEDs
Channel Vision's IR-1203 amplified IR hub is designed to integrate a distributed IR control system into homes, offices, or retail showrooms quickly. The small hub housing features two screw down tabs for mounting to just about any flat surface. Screw down terminals offer secure IR target connection for providing signal to the four 3.5 mm emitter output jacks. Simple system expansion, and alternate target connection, is provided via a 3.5 mm signal input and a 12 VDC, 250 mA power supply is included. Status LEDs indicate power and signal condition Compatible with most IR systems. IR targets and emitters are required for operation and are not included.
Specifications: • System voltage range: 8-12 VDC • IR frequency range supported: 30-60 kHz • Dimensions: 4.25" H x 1.03" W x 1.10" D.
  • BrandChannel Vision
  • ModelIR-1203
  • Part Number183-195
  • UPC690240023879
  • Product CategoryIR Engines / Hubs
  • Weight0.66 lbs.
View similar products to the Channel Vision IR-1203 Amplified IR Repeater Hub
in the IR Engines / Hubs product category.
What is the most sensitive IR target that can be used with this repeater?  I need to bounce of the front wall and back to overhead where the projector is.
Asked by: aviatrix2
The receiver that is designed to work with this system is the IR-2400 which can be seen below.http://www.parts-express.com/channel-vision-ir-2400-ir-repeater-receiver--183-202
Date published: 2014-01-08
  • 2016-02-14T08:02CST
  • loc_en_US, sid_183-195, PRD, sort_recentQuestionsFirst
