Channel Vision HS-8 8-Way Splitter/Combiner
Brand:|Model: HS-8|Part # 183-138
These splitter/combiners utilize a PCB that ensures a superior flow of RF signal, allowing them to act as true combination RF splitter/combiners.
List Price$38.89
You Save32%
$26.33
Part # 183-138
  • Printed PCB circuit board
  • Nickel plated housing
  • DC and IR passing
  • 5-1000 MHz bandwidth
These splitter/combiners utilize a PCB that ensures a superior flow of RF signal, allowing them to act as true combination RF splitter/combiners. Each splitter/combiner has a high port-to-port isolation, preventing ghosting or ingress issues. Available in 2, 3, 4, 6, 8, 8 vertical, and 16 outputs.
Specifications: • Number of outputs: 8 • Bandwidth: 5-1000 MHz • Insertion loss: 11 dB • DC passing • IR passing.
  • BrandChannel Vision
  • ModelHS-8
  • Part Number183-138
  • UPC690240011104
  • Product CategorySplitters & Combiners
    (4 Reviews)
  • Weight0.65 lbs.
View similar products to the Channel Vision HS-8 8-Way Splitter/Combiner
in the Splitters & Combiners product category.
Channel Vision HS-8 8-Way Splitter/Combiner is rated 4.5 out of 5 by 4.
Rated 4 out of 5 by from Good splitter but okay combinerI bought this unit after the cheaper version (p/n 183-140) did not quite work well enough. Unfortunately, I have the same problem with this one. When using the unit as a combiner, channels or frequencies next to each other on the spectrum will interfere with each other. You will need to make sure and skip a channel in the frequency band. I am using the VHF band and have the same problem whether using an amp, a modulator, or sat/cable box. Other than that, the unit works fine.
Date published: 2009-05-25
Rated 4 out of 5 by from Decent value, well-made, works as advertisedDecent value, well-made, works as advertised
Date published: 2008-03-05
Rated 5 out of 5 by from Great SplitterAs usual Parts Express got it to me quick. This splitter works great in my home media system. With the intro of Home Theater and HDTV, upgraded all equipment except RF wiring. Over-the-air digital TV wiring is more sensitive to perfections (operates at UHF and not VHF at all), higher carrier frequencies. All my old RF "stuff" came from RS (not the best). This splitter lets me get rid of one amplifier in my media distribution system. The front end amp I replaced with one from Parts Express also and it has the amplification needed to drive this splitter. This splitter has all the attributes required: strong box, easy mounting, ect.
Date published: 2007-11-15
Rated 5 out of 5 by from Works great for cable tvmakes a great replacment for the one fourway and a threeway splitter the cable guy installed (plus a two way I added) for the total of seven TVs in my house, excellent digital signal at the cable box (ie it works now).
Date published: 2007-10-27
  • 2016-02-09T06:40CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_183-138, PRD, sort_mostRecent
