Channel Vision HS-2 2-Way Splitter/Combiner
Brand:|Model: HS-2|Part # 183-130
These splitter/combiners utilize a PCB that ensures a superior flow of RF signal, and allows them to act as true combination RF splitter/combiners.
List Price$8.98
You Save28%
$6.51
Part # 183-130
  • Printed PCB circuit board
  • Nickel plated housing
  • DC and IR passing
  • 5-1000 MHz bandwidth
These splitter/combiners utilize a PCB that ensures a superior flow of RF signal, and allows them to act as true combination RF splitter/combiners. Each splitter/combiner has a high port-to-port isolation, preventing ghosting or ingress issues. Available in 2, 3, 4, 6, 8, 8 vertical, and 16 outputs.
Specifications: • Number of outputs: 2 • Bandwidth: 5-1000 MHz • Insertion loss: 3.5 dB • DC passing • IR passing.
  • BrandChannel Vision
  • ModelHS-2
  • Part Number183-130
  • UPC690240011050
  • Product CategorySplitters & Combiners
    (8 Reviews)
  • Weight0.1 lbs.
View similar products to the Channel Vision HS-2 2-Way Splitter/Combiner
in the Splitters & Combiners product category.
Channel Vision HS-2 2-Way Splitter/Combiner is rated 3.875 out of 5 by 8.
Rated 1 out of 5 by from Poor qualityDC pass Splitter / Combiner works as described has very poor case and connector castings. Ends of cast connectors (not machined) are very rough not a reliable water proof seal. Even the CHANNEL VISION sticker doesn't fit - over laps the case. Recommend buying better quality part.
Date published: 2015-09-03
Rated 5 out of 5 by from Works well. No issuesSolid design - full casting, no backplate. It's beefier than the photo suggests. I just needed to split cable/modem connection and didn't need the DC pass-through function. I didn't shop around. The price was right for the wide bandwidth.
Date published: 2015-02-15
Rated 5 out of 5 by from Worked fine for amateurWorks fine, no noticeable signal loss.My system's all audio, bare bones for video and am amateur at video. Needed a splitter for my super cheapest Coby TV that had no line-level outputs for audio. Had to use an analog to digital TV converter for it's audio outputs.Anyhow works great, seems solid, plus DC passthrough helped for pre-amped antenna. Am only amateur so check other reviews for more in depth info.
Date published: 2010-03-25
Rated 5 out of 5 by from Works as advertisedI needed a DC passing splitter when I discovered my mast mounted preamp would not operate with a normal splitter due to the power supply being on the other side of the splitter. The HS-2 does the job nicely, my preamp is now happy again. It appears to be pretty ruggedly constructed and I did not notice an appreciable insertion loss, so all is good.
Date published: 2009-05-11
Rated 4 out of 5 by from Great Product. Not so much the price.It s a great product. It s a useful tool for cable internet and for Sat TV aplications.
Date published: 2008-06-11
Rated 1 out of 5 by from Don't expect to get the pictured productThe unit pictured with the two open u-shape mounting tabs on the left is the original version -- which I was expecting to get. What was shipped were larger units [same part number, but clearly different than pictured]. Size wasn't that important to me, but the new ones do not have the teflon insulated connectors which were always standard on channel vision. Not a step forward.
Date published: 2008-04-21
  • 2016-02-06T07:16CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_183-130, PRD, sort_mostRecent
