Channel Vision ARIA A0350 In-Wall 2 x 50W Class-D Amplifier
Brand:|Model: A0350|Part # 183-256
The ARIA A0350 in-wall amplifier from Channel Vision is perfect for use with their wireless audio transmitters and receivers to create your custom distributed audio system. The Class-D 50W x 2 amplifier can also work as an in-speaker amplifier.
A restocked/refurbished, or Open Box unit of the product is available -- see it now
List Price$250.00
You Save41%
$148.50
Part # 183-256
  • 100 watt integrated class D amplifier
  • Auto-on circuitry
  • Pre-amp audio outputs for easy connection to powered subwoofer
  • Local audio input to override the CAT5 audio input
  • Input for compatibility with Channel Vision’s CAT5 audio systems
Channel Vision's ARIA A0350 is an in-wall, high performance, 100 watt (50 watts by 2 channels) Class-D audio amplifier with features that are unmatched by the closest competitor. The A0350 double gang, flush mount amplifier can be used with Channel Vision’s CAT5 audio signal distribution hubs, local signal sources via the front-mounted RCA inputs, and can pass along signal to an additional local amplifier (or subwoofer) through the rear-mounted RCA outputs.
This amplifier can also be installed in a speaker cabinet for use as a bi-amplifier, or can power a master/slave speaker combination through the use of the internal and external speaker outputs. Volume control of the A0350 can be controlled by the local source or an A0127 keypad. Maximum gain and balance adjustments are located on the rear of the amplifier. 24 VDC power supply included.
• Power input: 24 VDC
• Output power: 50 watts RMS x 2 (6 ohms @ <10% THD)
• Frequency response: 20-20,000 Hz (± 3 dB)
• Signal-to-noise ratio: >85 dB
• Input sensitivity: 500 mV RMS
• Auto-on threshold: 10 mV RMS
  • BrandChannel Vision
  • ModelA0350
  • Part Number183-256
  • UPC690240025828
  • Product CategoryAudio Distribution Systems
  • Weight2.05 lbs.
View similar products to the Channel Vision ARIA A0350 In-Wall 2 x 50W Class-D Amplifier
in the Audio Distribution Systems product category.
