Channel Plus LPF750 Low Pass Filter 40-750 MHz
Brand:| Model: LPF750
Cable TV bandpass filter for channel 2-116 A low pass filter is used on systems when the broadband entertainment feed is supplied by a CATV service. The filter removes all CATV channels above the pass band, allowing insertion of locally operated channels.
180-784
Weight: 0.25 lbs.
IN STOCK
List Price$61.89
You Save19%
$49.99
Part # 180-784
A low pass filter is used on systems when the broadband entertainment feed is supplied by a CATV service. Many cable tv operators send spurious signals on unused upper channels making them also unusable for local modulators. This filter reduces the level of CATV channels above the pass band, allowing insertion of locally modulated channels above the filter channels.. Filters may also remove cable system noise on other in-band channels. Male to female F connectors make fast in-line installation simple. Passive design requires no external power supply. Dimensions 1" x 3" This filter passes channels 2 thru 116. Channel Plus part number LPF750
  • BrandChannel Plus
  • ModelLPF750
  • Part Number180-784
  • UPC782644006395
  • Product CategoryCable TV Filters
    (3 Reviews)
  • Weight0.25 lbs.
View similar products to the Channel Plus LPF750 Low Pass Filter 40-750 MHz
in the Cable TV Filters product category.
Channel Plus LPF750 Low Pass Filter 40-750 MHz is rated 4.0 out of 5 by 3.
Rated 4 out of 5 by from Know about modulation first!This works perfectly fine but you have to know about channel modulation and cable companies channel line up first!
Date published: 2009-07-23
Rated 4 out of 5 by from Great brandWorked as intended... except channel 116 still leaks a bit. 117 on are clean.
Date published: 2008-07-08
Rated 4 out of 5 by from Low Pass Filter Works Very WellChannel Plus has always produced high quality products. While other generic low pass filters are cheaper, I prefer to stay with the more expensive Channel Plus filters that have always worked well for me. This product blocks channels greater than 116 so that you can use that channel space for modulated signals. However consider using the LPF600 model instead to get more channels available for insertion. Even though the LPF600 blocks channels greater than 86, it will not block cable channels in the 90-99 range, since they are in a different band. The LPF600 thus allows you to use any channel over 100 for modulated insertion.
Date published: 2008-02-06
Customer projects that include: Channel Plus LPF750 Low Pass Filter 40-750 MHz
