CLEARANCE
Channel Plus LPF600 Low Pass Filter
Brand:|Model: LPF600|Part # 180-780
Cable TV bandpass filter for channel 2-86 A low pass filter is used on systems when the broadband entertainment feed is supplied by a CATV service. The filter removes all CATV channels above the pass band, allowing insertion of locally operated channels.
List Price$61.89
You Save19%
$49.99
Part # 180-780
A low pass filter is used on systems when the broadband entertainment feed is supplied by a CATV service. Many cable tv operators send spurious signals on unused upper channels making them also unusable for local modulators. This filter reduces the level of CATV channels above the pass band, allowing insertion of locally modulated channels above the filter channels.. Filters may also remove cable system noise on other in-band channels. Male to female F connectors make fast in-line installation simple. Passive design requires no external power supply. Dimensions 1" x 3" This filter passes channels 2 thru 86. Channel Plus part number LPF600
  • BrandChannel Plus
  • ModelLPF600
  • Part Number180-780
  • UPC782644003110
  • Product CategoryCable TV Filters
    (4 Reviews)
  • Weight0.225 lbs.
View similar products to the Channel Plus LPF600 Low Pass Filter
in the Cable TV Filters product category.
