Cerwin-Vega JE-36C 18" Folded Horn Subwoofer System 3" VC Woofer
Brand:|Model: JE-36C|Part # 246-406
The JE-36C folded horn subwoofer system by Cetwin-Vega is an 18" cabinet with 2,000 watts peak power, 3" voicecoil, and a thunderous bass frequency extension similar to a 36" driver and five feet of folded horn chamber length in the cabinet.
Part # 246-406
  • Rugged cast aluminum C-Series door has improved heat dissipation capabilities
  • Increased low frequency SPL from improved cabinet bracing
  • Rounded horn mouth creates smoother frequency response
  • Steel front corner bracing to improve cabinet strength
  • Casters repositioned for increased front/back stability
  • Redesigned durable Multi-ply construction
  • An extra-deep, reinforced pole cup that keeps pole-mounted speakers stable
The JE-36C is the latest edition of the "Junior Earthquake" folded horn subwoofer system and provides extreme value in a compact design. However, there is nothing junior about this subwoofer. A new cabinet design provides increased SPL and low frequency performance suitable for mobile DJs and club applications. A striking die cast door has improved heat dissipation capabilities. The curved horn mouth bracing provides a smoother frequency response. Front corner bracing and a reinforced pole cup (almost twice as deep as the previous version) offer extra durability.
Cerwin-Vega! Folded Horns: Often Imitated, Never Duplicated
Cerwin-Vega's folded horn subwoofers are THE standard when it comes to folded horns. These subwoofers combine advanced design, superior speaker technology and precision manufacturing to deliver a product that is truly a sonic experience. The Cerwin-Vega! folded horns have been acoustically optimized to achieve high output and low distortion while maintaining clarity and impact. Special attention to rear chamber, throat geometry, and horn profile results in a folded horn design that doesn't exhibit the typical horn coloration of competing products. Cerwin-Vega! folded horns contain a longer sound path which amplifies the bass frequencies while keeping the enclosure compact in size for portability. The path length and flare rate deliver bone crushing low-end down to 29 Hz.
Many companies attempt to duplicate Cerwin-Vega's performance in folded horns, but ultimately they all fall (and sound) flat. A great folded horn is as much about the loudspeaker driver design as it is about the cabinet geometry. Cerwin-Vega! is the ONLY company (in our not so humble, 50+ years of experience opinion) to get all of these factors perfectly tuned and balanced. A Cerwin-Vega! folded horn plays louder, sounds better and will stick with you longer than the "clones."
Brutally Efficient
Cerwin-Vega! folded horns, on average, produce 6 dB more output at 1 watt than ported direct fire subwoofers. This results in two times the SPL output with half the number of drivers. System costs are drastically reduced due to the need for fewer cabinets. Powering far fewer cabinets yields large cost savings in amplification. The net result is loud sub bass that moves enough air to blow the hairpiece off the competition. If you do pair the folded horns, you'll get the added benefit of an increased horn mouth area effectively extending the low frequency range and mutual low frequency coupling, which doubles the low frequency amplitude. The result? A mind-blowing level of bass performance like nothing you've experienced.
Ready for Roadies
Of course, the C-Series folded horn systems have integrated wheels and a new Cerwin-Vega! ergonomic handle for increased portability. The ergonomic design allows the C-Series to be moved by a single person.
Power capacity
500 watts RMS, 1,000 watts program, 2,000 watts peak
Frequency response-3 dB, 44 Hz - 281 Hz/ -10 dB, 37.5 Hz - 335 Hz
Input connectors
1/4" phono, Speakon
Recommended power
750 watts - 1,000 watts @ 8 ohms
Sensitivity (1w/1m)
106 dB
Nominal impedance
8 ohms
36" x 24" x 24"
121 lbs.
  • ConfigurationSubwoofer
  • Woofer Size18"
  • BrandCerwin-Vega
  • ModelJE-36C
  • Part Number246-406
  • UPC743658901182
  • Weight128 lbs.
View similar products to the Cerwin-Vega JE-36C 18" Folded Horn Subwoofer System 3" VC Woofer
