Cerwin-Vega INT-152 V2 Intense 15" 2-Way Full-Range PA Speaker
Brand:|Model: INT-152 V2|Part # 246-414
Cerwin-Vega's INT-152V2 PA speaker sure is intense with up to 800 watts peak power, increased magnet size of its 34 mm compression drivers, and PTC thermistor protected tweeter.
Part # 246-414
  • 34 mm compression drivers
  • Steel frame woofers
  • PTC thermistor protected tweeter
  • Black carpet finish
  • 15 mm reinforced cabinet
  • Speakon® and 1/4" inputs
  • All metal handles with stamped CV logo
The Intense series from Cerwin-Vega! has established a well-deserved reputation for providing extraordinary and impactful sound at an affordable price. How do you enhance a leading product in its class? Improve the product components, sound quality AND lower the price! Introducing the new Intense! V2. Perfect for PA applications such as live sound, program playback, and DJ systems - it can be installed in facilities, venues and clubs – yet it is fully portable for sound on the go. Now with stronger drivers with the addition of more steel. Upgraded the cabinet construction with internal bracing for enhanced durability. Improved dependability from a new positive temperature coefficient (PTC) thermistor that protects the tweeter. This component acts as a self -repairing fuse allowing the speaker to return to normal operation once the input fault is corrected.
Power handling
200 watts RMS, 400 watts program, 800 watts peak
Frequency response±3 dB, 64 Hz - 19.8 kHz
Frequency response (1w/1m)-10 dB, 46 Hz
Calculated max output
Full range 124 dB
Nominal coverage angle
Horizontal 90°, Vertical 50°
Axial sensitivity
Full range 95 dB
Nominal impedance
Full range 8 ohms
Dimensions
30.75" x 18.5" x 10.375" x 19.25"
Weight
57.7 lbs.
  • Woofer Size15"
  • BrandCerwin-Vega
  • ModelINT-152 V2
  • Part Number246-414
  • UPC743658901403
    (1 Reviews)
  • Weight71 lbs.
View similar products to the Cerwin-Vega INT-152 V2 Intense 15" 2-Way Full-Range PA Speaker
